Multiplex Twister EDF
Here is my new Multiplex Twister EDF. Great kit and built using the stock EDF unit and motor. Very happy with performance (no doubt will upgrade later). This is very easy way to get into EDF flying with the kit containing everything you need with the exception of the servos, ESC, receiver and battery.
Multiplex have used quality fittings and I did not need to replace anything.
Only thing I did a little different was to paint the whole aeroplane with a gloss white with some trim paint and then add the included decals to spice it up a little.
Flies great and builds up a nice little howling sound coming downwind - slows down to a walk for landings. It will of course, get away a little from you and being small in size, it does not pay to let it get too far away. Fly close and enjoy the view!!
Big thumbs up from me!!
Spektrum AR6100E, Hitec HS-55 servos, Extreme RC 3S 3300 lipo.
Hey now,
Got one when they first came out. Loved it, still have it and fly it whenever visability is good enough. I kept mine stock and see no reason to hot rod it it's plenty fast for what it is.
If I want fast and jet I prefer the HET jets, I have a F-20 and F-104 (the 104 is still on the boards), but the Twister is a fun to fly relaxing jet and prolly the best entry level jet on the market, and I have several foamie jets...
I like the paint on this one, looks very good.
RobII
RobII
Drop a 2W20 and 6904 fan when you are ready Keith, one of the best plug and play upgrade packages around for the twister. 2500-3300 4s pack is needed, the 2500 is much easier to get balanced but short flight times. Guy who flies with us has been running anything on hand up to 5000 4s1p! bit nose heavy but handles it amazingly well!
Hi Guys: I shot a video of my Twister yesterday and thought I'd share it with you. I can't zoom once I start recording and oh, its taped to the bill of my hat. The plane is stock except that I painted it red with Krylon plastic paint. I love this plane.
[media]http://www.youtube.com/watch?v=LskOsA_KZe8[/media]
Woo hoo! I finally figured out some iMovie stuff, and ta da! A new Twister vid!
Check it out! Crank up to HD, Full Screen, and blast your speakers!
http://youtu.be/7COLHzaEQek
I was given a crashed Twister .. repaired it .. left the modified Thrust Vector unit on he'd fitted.
It has Hoaye 70mm 6 blader in her (similar to stock) with a 3300kv motor on 4S 2700 ............ Any good ? To be honest - it's a dog.
It was a dog when he got it new and tried it stock ..
Faults :
a) Old style beaded foam
b) Elevator is too flexible.
c) Fin flexes when either elevator or rudder servo moves.
d) Nose is too bulky and heavy - needing the steel balls installed in tail - supplied in kit.
Very disappointed ... with a better nose design and tail - it could be a really fine looking machine .. but it really is old hat.
Sorry .. there are far better EDF machines out there .. I'm just glad that I didn't pay for this !!
Faults :
Yeah a lot of flyers call the Twister crap, but it's one of my favorites. Mine has a lot of major battle damage that has been lovingly repaired back to near perfection. My buddies and I fly at a vacant lot just north of Ramac Park in South San Jose, California.
My Twister is powered by a HET 2W-20 and Wemotec dynamically balanced 9-blade MiniFan unit on 4s through a Gecko 65A ESC. Max static power almost 1KW, which would drive "better" EDF planes at twice the speed.
But whenever I fly it, everyone in sight is totally loving it! "That's freaking AWESOME!" is the most common comment from spectators.
Looking to build a brand new twister. I always liked this plane. Plenty of new technology out there. Saw three videos online with 12/14 Blade units - the sound and flight characteristics were great but very little information was given on the setups. I am framilar with all the various aero Mods for the twister. What power setup do you recommend for a 12/14 CS fan? I will buy what ever battery and efc is required to run the CS fan properly. That being said, I would like to keep the battery in the 3s or 4s range to limit the twister's nose heavy tendency. There is so much conflicting info out there, what do the experts recommend? If someone could recommend both a 3s and 4s options for the CS12/14 Blade units, I would be mosy appreciative. Thank you.
I have THIS 4S 12 blade fan/motor combo on the way and should be here Tuesday. Don't hold your breath for much test info from me though. I don't have any 4S packs right now to test with. TONS of 3S in all capacities though......
It's a big ole draggy bird and I'm sure it needs a lot of power to haul its bulk around the sky. I don't need 150+ mph though. Just reliable and sorta fast and I'll be quite pleased.
Of course somebody will now step in and suggest only a 12S setup with X amount of blades and X amount of KV for 300+ mph speeds.
Joe
Joe
