Combat Electric combat discussion in here.
Is Streamer Combat Possible for Flying Wings
Old 07-06-2008, 01:21 AM
goofeyfoot
Default Is Streamer Combat Possible for Flying Wings
Hello:
A friend and i fly delta epp wings all the time. We were thinking about trying streamers or something like that. I thought that with pusher props that would be impossible.
Is something like this possible to do? If so, where could I find out more?
Thanks for your help.
Michael
goofeyfoot is offline
Old 07-06-2008, 01:25 AM
SkunkyMagoo
Newborn Rotorhead
SkunkyMagoo's Avatar
If you hit it right you will chop up the streamer no problem. A lot of people use wings cor streamer combat.
SkunkyMagoo is offline
Old 07-06-2008, 01:46 AM
goofeyfoot
Well, we were thinking of doing it a little differently. You would have double sided sticky tape on the leading edge of the plane. You would fly through the streamer and that leading edge tape would shred the streamer - it would rip it off, essentially.
I was more concerned that maybe your own streamer would get caught in your prop and just make a mess.
What do you guys think?
Thanks.
Michael
Old 07-06-2008, 01:48 AM
SkunkyMagoo
Newborn Rotorhead
Ohhh,
Use those thin party paper streamers, they will get shredded and will not get caught up in the prop shaft.
Old 07-06-2008, 03:31 AM
goofeyfoot
Ohhh,
Will definitely give this a try. Can't wait.
But doesn't your own tail get caught in your own prop?
Thanks, and best regards.
Michael
Old 07-06-2008, 03:48 AM
SkunkyMagoo
Newborn Rotorhead
Not unless you can turn inside yourself
Old 07-06-2008, 05:36 AM
goofeyfoot
Well yes that would be true for a regular plane, but here we're talking about delta wings that have the prop on the back. Don't the streamers get snagged right in your own prop?
Thanks.
Michael
Old 07-06-2008, 06:33 AM
Dorsal
If it Flies, I love it!
Dorsal's Avatar
Use 2 streamers, one tied to each wingtip.
Dorsal is offline
Old 07-06-2008, 10:15 AM
Balil
foam murderer :D
Balil's Avatar
yeah, as long as you mount the streamers on the tip of each end you shouldnt have a problem w/ them getting caught in the prop. ive flown streamer combat w/ my stryker a time or too. but full contact combat is alot more fun by far... but people dont typically like trashing planes
Balil is offline
Old 07-06-2008, 11:57 AM
goofeyfoot
OK, will give it a go.
Michael
Old 07-10-2008, 08:16 AM
crash_out
Misanthropic Member
crash_out's Avatar
I've done it with a string running from the rear of one wingtip to another, and a leader string in the center of that one with the streamer attached to that. I've flown it against dedicated RCCA combat planes, just for fun.
In contests, most combat flyers use a product called Tanglefoot on the leading edge of the wings to snag streamers. This stuff is VERY sticky, and takes mineral spirits to remove. I've used double sided tape as well as small strips of sandpaper on my swept wings.
crash_out is offline
Page generated in 0.10509 seconds with 13 queries
