Scratchbuilt Foamies
Old 07-30-2007, 04:16 AM
  #151
kaos2
kaos2's Avatar
Originally Posted by Prof100 View Post
It is 1/2" step.
What is the wing's chord?
kaos2 is offline
Old 07-30-2007, 05:40 AM
  #152
Prof100
7.25"
Prof100 is offline
Old 07-30-2007, 02:06 PM
  #153
kaos2
kaos2's Avatar
7.25"
Ahhhh. I see what you've got going on here. On a bottom-step KF wing, the step height is measured from the step, to the top side of the wing. The percentage is actaully the total wing thickness relative to the wing's chord, not just the height of the step above or below the material to which the step is attached. Your "1/2 inch" step is actually a 10% step, not a 7% step. This is assuming that the the wing thickness prior to the addition of the step was the same thickness as FFF. If it was thicker than FFF, your step is greater than 10%. If you really want to try the KF wing designed as others are using it prersently, I think you need to reduce the step height filler material to 1/8" or zero. A KF step created by the thickness fo FFF alone would be in the 7% range for a wing chord of 7.25". A 1/8" filler height would guve you a 8.25% KF step height. Both of those steps will fly very well. The wing shape you're attempting to fly has already been assessed by someone and determined to be unacceptable. Of course, this is all based on my present understanding and experience with the KF wing. I'm not trying to be critical, just helpful.
Good luck.
kaos2 is offline
Old 07-30-2007, 02:20 PM
  #154
Prof100
Good luck.
Well, well, well I truly deserve the dumbass award for this one. Or, maybe dumbass is the incorrect term. I am simply ignorant of all the facts.
Yes, the 1/2" step is truly the height of the step I added. The thickness of the fan fold and basswood square piece spacer equals 1/2 inch. A Super Cub is NOT a flat wing. Guesstimating the wing thickness prior to to adding the step I would say it is close to one inch so the total is 1.5". Doing the calculation again (dividing 1.5" by 7.125" cord) equals 21%. That might explain the evil handling I was experiencing. It sure as heck wanted to climb with this configuration.
Simply adding a 1/4" (approximate) thick piece of fan fold to the plane would work. Correct? Should I taper the front leading edge of the fanfold or leaving blunt?
Prof100 is offline
Old 07-30-2007, 02:32 PM
  #155
kaos2
kaos2's Avatar
Now, now, now............Don't be too hard on yourself! Whenever a person is trying to learn something, sometimes there's little setbacks.
Yes, the easiest way to try this out is using a single piece of FFF. I would "round" the leading edge if possible. One of the advantages of the KF design over a flat plate or UC 'foil is a thicker leading edge. This results in less pitchyness (is that a word? ).
When adding a step to the bottom side of a UC wing, my recommendation is to adjust the step height so that IF the step were extended all the way to the trailing edge of the wing, the resulting airfoil would be the flat bottom type.
I think we're on the right track now!
kaos2 is offline
Old 07-30-2007, 03:09 PM
  #156
Prof100
Now comes the task of removing all of the packing tape I used to install it. A fresh hobby knife blade ought to do. Removing the spacers will be easy. I did glue them on but only to the fanfold.
Prof100 is offline
Old 07-30-2007, 03:25 PM
  #157
kaos2
kaos2's Avatar
Default Hijack Concern
I'm concerned that the discussion about the KF wing may be hijacking the Scratchbuilt Foamies thread. My original post was sharing a scratch built plane that I designed that utilized a KF airfoil. Lately, the discussion here seems to have focused around the KF airfoil and modifing existing designs to the KF airfoil. Do I need to start a separate KF Wing thread? Is there enough interest?
Regardless of what we do, I never intended to hijack this thread.
kaos2 is offline
Old 07-30-2007, 03:29 PM
  #158
Prof100
I plead guilty to the charge of hijacking, or at least a conspirator. Yes, I think a new thread for the KF wing is in order.
Prof100 is offline
Old 07-30-2007, 03:53 PM
  #159
snolord1
http://www.youtube.com/watch?v=uVuhLJ17L08
snolord1 is offline
Old 07-30-2007, 03:54 PM
  #160
kaos2
kaos2's Avatar
I've created a new thread about the KF airfoil. Anyone wishing to participate in further KF discussion, please post in the new thread. Sorry Crashalott.
Link to KF Wing thread. http://www.wattflyer.com/forums/showthread.php?t=22654
kaos2 is offline
Old 08-04-2007, 07:40 PM
  #161
snolord1
Default Su9
WS: 15"
length:25.5"
don't ask,i don't know if it will fly but i'm going to try anyway.
i looked at the 3 View and liked the looks of it.the only prob. was that when i enlarged it,it was still too small for my taste but decided to give it a try anyway.
weight of airframe alone is 2.54oz
the set up will be:
LensRc 8T w/4x3 prop
3s540mA [email protected]
CC10 ESC
2 x 4.3g servos
Berg 4L Rx
edf40 w/ feigao ips motor might be another option for power.
let me know what you guys think,any suggestions all input is welcomed.
thnx
Angel
ID:	37314   Click image for larger version
ID:	37315   Click image for larger version
ID:	37316   Click image for larger version
ID:	37317   Click image for larger version
snolord1 is offline
Old 08-07-2007, 04:00 AM
  #162
snolord1
or this one
ID:	37514   Click image for larger version
snolord1 is offline
Old 08-12-2007, 04:26 AM
  #163
beanie
snolord1, i'm sure you'll get your Su9 flying.
here are a couple of my scratch builds... MiG-23 swing wing, Boeing 727, RFB Fantrainer and MiG-25. this MiG-23 is actually a 130% of my original MiG-23 design. i added some 'afterburners' this time around. the Boeing 727 has still yet to maiden, but i've been too busy with some other scratch projects at the moment.
-beanie
ID:	37900   Click image for larger version
ID:	37901   Click image for larger version
ID:	37902   Click image for larger version
Name:	Fantrainer64 06 5-05.jpg
ID:	37903   Click image for larger version
beanie is offline
Old 10-16-2007, 10:35 PM
  #164
smokejohnson
smokejohnson's Avatar
More of a kit built than a scratch built since this was made from one of Saucerguy's P-40 kits. It's my new favorite. Now I can retire my E-Starter and build a Regal .
smokejohnson is offline
Old 10-23-2007, 06:56 PM
  #165
tramp8754
tramp8754's Avatar
Default some of my foamies
Video:
Blackwing: http://www.youtube.com/watch?v=Uq8tPBViu3U
Geobat: http://www.youtube.com/watch?v=S3ORS-E6N8o
Geobat maiden: http://www.youtube.com/watch?v=LLyk62KFYWA
Geobat elevons: http://www.youtube.com/watch?v=4tgMXHpoBZU
F117: http://www.youtube.com/watch?v=_N_lsTtn2ng
ID:	45373   Click image for larger version
ID:	45374   Click image for larger version
ID:	45375   Click image for larger version
ID:	45376   Click image for larger version
Name:	Mini Horten.jpg
ID:	45378   Click image for larger version
tramp8754 is offline
Old 10-23-2007, 07:11 PM
  #166
Prof100
tramp8754,
Nice videos, great looking planes. Liked the music too. The Geobat needs some strobes on it for night flying. Make sure the strobes circle the plane. Fly it at night over a Friday night high school football game and they'll be a gazillion UFO reports and probably a visit from Homeland Security.
Prof100 is offline
Old 10-29-2007, 05:20 PM
  #167
tramp8754
tramp8754's Avatar
Flying over a Friday night high school football game did cross my mind. Look at the video again. The bright lights in the distance are just that...a high school football game.
Going to fly today. Hope to have more video posted late this evening.
Old 10-31-2007, 03:40 PM
  #168
Crashalott
Crashalott's Avatar
Here is my latest scratch build. A P51 Mustang from a Gene Bond plan of a profile P51 with a midwing. I changed it to a low wing with a bottom step.
The paint job i done on it was from a picture of a Voodoo Mustang i seen.
Have not done the maiden yet. Waiting for wind to die.
Crashalott is offline
Old 10-31-2007, 06:47 PM
  #169
tramp8754
tramp8754's Avatar
Default Mini Horten foamy videos
http://www.youtube.com/watch?v=Rjp85oIAiIs
http://www.youtube.com/watch?v=kmWMNLk25jI
Old 11-02-2007, 05:40 AM
  #170
tramp8754
tramp8754's Avatar
http://www.youtube.com/watch?v=pbgGmfbSEO4 Splash 3D
http://www.youtube.com/watch?v=ClZQprvtFhc Pterodactyl crash
Pterodactyl has been repaired and should fly next time.
Old 11-02-2007, 05:56 AM
  #171
Originally Posted by snolord1 View Post
WS: 15"
length:25.5"
the set up will be:
CC10 ESC
2 x 4.3g servos
Berg 4L Rx
thnx
Angel
Hi Snolord did you get your Su9 flying? I made a f16 with a 16" wing span, and used a 2500kv motor from heads up rc with a 5x3 prop and a 1000mah 3 cell lipo, my first maiden was scary, but it told me what was wrong with it and the 2nd maiden, it flew great, here is a video of it, my camera person was getting tired, as this was the second video she shot that day, so I had to trim a lot from it, enjoy, Chellie
Old 11-02-2007, 06:06 AM
  #172
Hi Tramp Really nice splash 3d hydro, well done, Take care, Chellie
Old 11-04-2007, 12:49 AM
  #173
tramp8754
tramp8754's Avatar
Just came to me, my post #169 should not be here. Two acft there were not scratch built. Foamy, yes. Scratch, no.
Old 11-04-2007, 05:53 AM
  #174
lmopar69
Gravity Stinks!!
lmopar69's Avatar
Here is the most recent pic of my current scratch built project, the Ohio Combat SRT/10. Yeah, it REALLY is that big guys!
Laine.
Name:	Me and SRT.JPG
ID:	46076   Click image for larger version
Name:	Me and SRT2.JPG
lmopar69 is offline
Old 11-04-2007, 07:51 AM
  #175
bowtie hi
There you are again Chellie. Up late past my bedtime.
Ken
bowtie hi is offline
Quick Reply: Scratchbuilt Foamies
Page generated in 0.16625 seconds with 32 queries
