Old 09-09-2017, 04:28 PM   #1
garyp1029
Default PowerUp 10---Improved Performance?
I have a PowerUp 10 from HeadsUp and am thinking of putting it into my old Parkzone T28. The stock motor---480 960kv---is a 35X33 and weighs 87 grams. The PowerUp 10 is 35X35 and weighs 102 grams. My question---Is it likely, or even possible, that the Power 10 will produce significantly improved performance when the stats are so close? If possible, please explain.
Thanks. Gary
garyp1029 is offline
Old 09-09-2017, 06:32 PM   #2
Contact the very friendly and knowledgeable customer service center at HeadsUp.......they always respond and know more about their products and match-ups than anyone else....!
Old 09-09-2017, 07:35 PM   #3
Turbojoe
Mountain Models Minion
Turbojoe's Avatar
Friends: (12)
Keep in mind that there is a major storm barreling into their area of Florida. I wouldn't expect a reply from them for many days. That said I just got my 14th order from them yesterday. Love those guys! No matter what they seem to make things happen and ON TIME!!
Joe
The nonsensical ravings of a lunatic mind.....
Turbojoe is offline
Old 09-10-2017, 10:49 AM   #4
Bear in mind that the power up 10 comes in two different Kv values, 1000Kv and 1450Kv.
The 1000Kv motor should be a straight replacement and should spin the same size prop, maybe with a modest performance increase. The 1450Kv version would have to run a smaller prop, about 75% of the original prop diameter. Heads-Up have prop tables for their motors which is a good guide.
As with any motor/prop swapping, it's highly recommended to check with a wattmeter to make sure the full throttle current is within motor and ESC limits.
Old 09-10-2017, 06:06 PM   #5
garyp1029
My PowerUp 10 is the 1000kv model. I can't see that it would provide much improvement over the stock motor---35X33 vs 35X35.
Old 09-12-2017, 06:20 AM   #6
The Power-up is slightly higher Kv (1000 vs 960) so if the specs are accurate it will spin the prop slightly faster. Motor power is proportional to RPM^3 so a small difference in RPM makes a relatively large difference in power. If the specs are 100% accurate you could expect to get (1000/960)^3 = 13% more power
So not a whole lot but maybe just about noticable (if the specs are accurate)
Old 09-12-2017, 04:37 PM   #7
View dahawk's Gallery6
Club: 114th RC Aero Squadron
100mph Speed Demon
Ha,
Why stop there? A group of us have souped up the T-28 with the Powerup 25. I'm running mine with a 60 amp esc on 4S 2700mah 40C lipos. Now before you do this, you need to beef up the airframe. We have added CF spars from arrows. taped up the h-stab. I literally blew mine off once. Hilarious. Talk about "blowing the doors off."
Almost turns the T-28 into a Reno racer. Now if you're really feeling the need for speed, get the Rochobby Strega or Voodoo Reno P-51's ( $200.00 @ MotionRC) and run on 6S with a 10x10 prop. Katie bar the door ! Faster than my fastest edf. Hauls the mail.
The nice thing about the eflight T-28 is that you can build a new one from spare parts for pretty cheap.
Have fun !
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 165 06-28-2017 04:22 PM
Wattflyer Buyers Club #10 2 Dog Yak 54 Inquiry thread Nitro Blast General Electric Discussions 12 02-26-2011 02:59 PM
Hanger 9 Showtime 50 Hacker Outrunner Flight Tests 6S2P A123 cell performance kyleservicetech Sport Planes (Formerly I/C & Gas Conversion) 11 05-29-2008 04:30 PM
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Page generated in 0.07767 seconds with 31 queries
