CAP PACK/Capacitor pack - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-22-2020, 02:47 AM
dasintex
dasintex's Avatar
Default CAP PACK/Capacitor pack
Twin Motor Plane 'Twin Otter', going to run 12" extensions from 4S 4500 MaH Lipo Battery in Fuselage to 60 AMP ESC's in Motor Pods/Mounts, going use Castle Creation CAP PACK next to ESC's
https://www.horizonhobby.com/CSE0110...iABEgKn2vD_BwE
Instructions for CAP PACK states for use with 8 inch extensions only, any problems stretching that out to 12 inches
dasintex is offline
Old 01-22-2020, 01:23 PM
Best electrical solution: battery packs in the nacelles or wings. Lowest resistance in battery and motor wires, lowest inductance in battery wires.
Second best: controllers in fuselage, near battery. Lowest battery wire inductance.
Too long wires batteryside will kill ESC over time: precautions, solutions & workarounds - RCG
Contents
  • Two problems
    ◦ Voltage spikes higher than battery voltage: transistor/FET/chip breakdown.
    ◦ Current through input capacitors too high: overheating/popping/exploding.
  • Example four costly controllers consecutively cremated
  • Solution I: simply lengthen the motor wires instead
  • Solution II: add extra capacitors, rules of thumb
    Calculation spreadsheet
  • Capacitor type and polarity/orientation!
  • How & where (not) to add extra capacitors.
    As close to or on controller.
  • DIY capacitor pack pictures
  • Capacitor & pack suppliers
  • Expert/manufacturer opinions & their rules of thumb
    They all say the same ... noise_reduction_101, switching_power_supply_design_101.
  • Cause, explanation, water hammer/knock analogy&video, theory
    References
  • Measurements & scope traces
Old 01-22-2020, 01:32 PM
dasintex
dasintex's Avatar
Appreciate the reply, I just assumed the ESC had to be next to the Motors, in my case the Battery has no choice but to be in the fuselage which means using about 12" extensions to the ESCs, extending the Motor Wires from the ESCs to the Motors a nice solution instead of the expense of Capacitor Packs
dasintex is offline
Old 01-22-2020, 02:05 PM
Just make sure the ESCs gets (moving) cooling air in the fuselage.
More reading, LiPo best care practices
www.rcgroups.com/forums/showthread.php?1767093-Battery-Load-Test-Comparisons/page835&perpage=10#post43327055
Stevephoon
557
08-09-2019 11:30 PM
hanick
06-24-2014 02:25 PM
jester_s1
01-29-2013 03:41 PM
popriv
3D Flying
08-04-2011 07:42 AM
Quick Reply: CAP PACK/Capacitor pack
Page generated in 0.05207 seconds with 10 queries
