How Do I Mount My Outrunner Motor ?
Old 11-29-2009, 03:09 AM
  #151
netjunky
Hi, for down thrust, add the washers on the top, that will angle the motor down, Take care and Happy Holidays to You, Chellie
thank you
netjunky is offline
Old 11-29-2009, 07:15 PM
  #152
BEAR-AvHistory
RDRC
BEAR-AvHistory's Avatar
Originally Posted by netjunky View Post
i have it mounted i just need to know weather to put the washer on the top or the bottom for -2 degrees down thrust
And an extra washer on the top left will give you down & right thrust.
The mount on the Seniorita is symmetrical because the fire wall is built with down - right when the plane is assembled.
The extra washers in the picture are to get the proper cowl to spinner clearance.
Also, Thanks for the kind words Chellie & hope you had a Great Thanksgiving.
BEAR-AvHistory is offline
Old 11-30-2009, 01:08 AM
  #153
Originally Posted by Octavius View Post
This is a 10g motor but I think it's still considered an outrunning. This works with a 24g motor too. Pictures should explain themselves.
For micro motors, that should be ok with the hot glue, as the hot glue is very strong, but i would not try that on any bigger motors Take care, Chellie
Old 11-30-2009, 07:17 PM
  #154
Octavius
Alien Surfer
Octavius's Avatar
Yes, definitely.
Octavius is offline
Old 11-30-2009, 08:41 PM
  #155
Kmot
Kmot's Avatar
Hey guys, I am setting up my first large electric plane. I had posted a question about the motor mount, because I thought it looked too flimsy. I was advised to not use it as is, and also to check this thread. Well, in this thread I have seen some photos of similar mounts. Now I am really confused!
ID:	114515   Click image for larger version
ID:	114516   Click image for larger version
Name:	000123 001_1.jpg
Kmot is offline
Old 11-30-2009, 08:57 PM
  #156
your mount looks great KMOT, someone did not have enough information to advise you correctly before, just use the largest diam. screws that will fit your motor mount, and use locktite hope that helps, Chellie
Old 11-30-2009, 09:31 PM
  #157
Octavius
Alien Surfer
Octavius's Avatar
I had posted this mount on the page before and generally like this type, but I think I need to add a little more. What I've found is if it's mounted on a wood stick the thrust angle can change a lot over time with simple wear-and-tear. 2-3 deg up or down. A hard landing can change it even more. Additional hard landings will continue to degrade the setup. I don't even mean a crash, but just hard landings or belly-flops for park fliers.
I only use aluminum sticks now and haven't seen any movement. The kind that come with something like the GWS SS.
Edit: Mount no longer made
ID:	114518   Click image for larger version
Octavius is offline
Old 11-30-2009, 10:33 PM
  #158
Kmot
Kmot's Avatar
Thank you Chellie.
The screws are 4x60mm, and I have decided to use nylon standoff's as well. I just set everything up and measured it, and I will be getting material to make 40mm standoff's.
Kmot is offline
Old 12-01-2009, 04:33 AM
  #159
Kmot
Kmot's Avatar
I lied. I made wood standoff's instead of nylon.
ID:	114616   Click image for larger version
Kmot is offline
Old 12-01-2009, 04:35 AM
  #160
That will work too
Old 12-01-2009, 10:50 PM
  #161
BEAR-AvHistory
RDRC
I have a few just like it only using light gauge sheet metal with what looks to be the same size bolts.
Only thing I would suggest is another piece of wood or X mount in the middle, with a bolt front & back, to stiffen the long unsupported span of the bolts against motor torque.
Old 12-02-2009, 12:08 AM
  #162
netjunky
Default difference betweet out and inrunner motors
hi,
was wondering if there was any difference between the outrunner and inrunner motors ?
netjunky is offline
Old 12-02-2009, 12:16 AM
  #163
Octavius
Alien Surfer
Octavius's Avatar
Typically outrunners are short, fat and the outer case (magnets) rotates so you can only mount from the end. Inrunners are longer the case does not spin, but only the shaft.
Octavius is offline
Old 12-10-2009, 08:32 PM
  #164
Octavius
Alien Surfer
Octavius's Avatar
Where do you guys buy your 10mm motors sticks? Either wood or aluminum. I've tried to shim-up 3/8" sticks but it doesn't work very well.
Octavius is offline
Old 12-11-2009, 05:30 AM
  #165
Here is what i do, and it works great, wrap some masking tape around the 3/8" stick so it fits the mount, and soak the wood and masking tape in some thin CA, it will be as hard as a rock and very strong, hope that helps, Chellie
Old 12-11-2009, 09:14 PM
  #166
Octavius
Alien Surfer
Octavius's Avatar
Thanks. That sounds like a plan. I just went to two shops and neither have replacement GWS Slow Stick fuse so that's out. Plus my guy can't get the aluminum mount I showed a few posts back.
Octavius is offline
Old 12-12-2009, 07:20 AM
  #167
Octavius
Alien Surfer
Octavius's Avatar
You all know I hate doing the huge circle of wood glued to the fuse with the large star mount. Plus it breaks off easy. I went through a couple poor designs. This is looking promising. 1/8 ply disk with 1/16 ply doublers. Th is just my plane template so it's not glued up yet.
ID:	115523   Click image for larger version
Octavius is offline
Old 12-12-2009, 08:24 AM
  #168
Perfect That looks great
Old 12-12-2009, 04:36 PM
  #169
Octavius
Alien Surfer
Octavius's Avatar
I feel I've been taught a lesson here. That E-flight mount you and I like, they stopped making it. Then I found that aluminum mount I like, they stopped making it.
This type is mount chews into the fuse much less as well.
Octavius is offline
Old 12-12-2009, 04:54 PM
  #170
Dr Kiwi
You could add triangular ply segments behind the disc to stiffen it up further (two on each side, from disc to plate, would do it).
Dr Kiwi is offline
Old 12-12-2009, 05:20 PM
  #171
netjunky
Default wing tiger
i have a friend with a wingtiger and he nosed it in the grass
now the motor runs wide open all the time he replaced the esc and the receiver and still does the same
any ideas what is wrong with it ?
netjunky is offline
Old 12-12-2009, 11:41 PM
  #172
My Best guess would be the motor is not feeding the esc the proper BEMF,because it got hurt in the crash, Since the ESC and Receiver have been already changed, or you might have a wire shorted out, between the receiver to the esc, hope that helps, Chellie
http://ww1.microchip.com/downloads/e...tes/01160A.pdf
Old 01-02-2010, 09:24 PM
  #173
Default Use Motor Mount Pictures
Hi Everyone Electric Flyer Magazine would like to use some of the Motor mount Pictures on this thread in their Magazine to help other Rc Builder/ Pilots, I told them they can use any and all the pictures that I have Posted, If there is no objection from other posters in 10 days from today, i will assume that its ok to use all the pics in this thread from all posters, just wanted to check and make sure that its ok with everyone that posted pics, Take care and have fun, Chellie
Old 01-03-2010, 05:02 AM
  #174
Octavius
Alien Surfer
Octavius's Avatar
I don't care either but just don't use the production mounts I posted because they're no longer made.
Octavius is offline
Old 01-03-2010, 06:21 AM
  #175
Thank you Octavius if you could edit the mounts that are no longer made , that will help, i need to do the same, as I have heard that E Flight no longer makes the super nice stick mount that i love so much Take care, Chellie
Quick Reply: How Do I Mount My Outrunner Motor ?
Page generated in 0.12254 seconds with 20 queries
