Mounting Motor
Old 07-15-2021, 10:49 AM
AcC8braman
Default Mounting Motor
Hi,
I have an unknown manufactured Yak 54-50. This can either be glow or Elec - so I'm going elec.
The motor I'm using is G60 - 500 kv.
The problem I have is the mount that came with the kit, the holes do not line up with the holes of the motor mount - I have penciled on the new positions - what would you suggest I do to properly do this
AcC8braman is offline
Old 07-15-2021, 12:41 PM
When I have met this problem - I have created a separate ply plate to glue on the inside of the mount box It only needs to be enough to give more strength to the new holes being so close to the old.
Of course the captive nuts etc. are all removed before epoxying in the plate. If weight is issue - then use PU Glue (Gorilla Glue).
OR
You could remove that box mount and use Stand-Off tube mounts ..... basically threaded tubes that stand the motor of required distance from the rear firewall.
Old 07-16-2021, 11:05 PM
RRW
I sink, ergo I exist
Good suggestion, in my case, I’d choose the same route.
RRW is offline
05-28-2020 09:50 PM
06-28-2017 04:22 PM
01-09-2017 02:23 AM
GoneFlyin74
01-27-2014 07:35 PM
terrynshed
06-29-2012 08:59 AM
Quick Reply: Mounting Motor
Page generated in 0.07734 seconds with 13 queries
