I'm looking for a motor/ESC combo recommendation for a 1/4 Cub
Old 02-09-2020, 06:34 AM
SWMO wingnut
Default I'm looking for a motor/ESC combo recommendation for a 1/4 Cub
Call it 17 pounds with all equipment. I'd like to find an ESC/motor combo that will allow me to use 2 6s batteries in series for a total 12s input. Or a 6s motor/ESC solution. Thank you
SWMO wingnut is offline
Old 02-09-2020, 06:06 PM
You could search for similar Cubs and just copy a good power system.
Do all your 6s packs have same capacity? A 12s pack of same capacity as a 6s pack has twice the energy and twice the mass, and it will let you fly twice as long.
Below an excellent quote about motor selection.
From
brushless motors Kv? - RCG.
The reason I suggest picking Kv last, is that prop choices have bounds - the diameter that will physically fit and the minimum size that can absorb the power you want. On the other hand, combinations of voltage and Kv are much less constrained - at least before you purchase the components.
So Kv is not a figure of merit, in that higher or lower is better, it is simply a motor characteristic that you exploit to make your power system do what you want, within the constraints you have, e.g. limited prop diameter, if it's a pusher configuration, or if you already have a bunch of 3S packs and don't want to buy more, and so on.
Minor lay-out changes by RvS
Old 02-09-2020, 08:08 PM
eCalc ... register for a few cents ... input basic info ... out pops the answer ...
Try different motor / prop / battery combinations - its often surprising what can be done ...
A-man
09-22-2013 03:51 AM
07-21-2013 12:52 AM
electrodude71
12-29-2012 05:31 PM
constantmotion
03-06-2011 02:49 AM
Quick Reply: I'm looking for a motor/ESC combo recommendation for a 1/4 Cub
Page generated in 0.09534 seconds with 14 queries
