Electronic Builders Workshop Discuss how to build motors, ESC's, chargers, mixers, etc here
hinges...
Old 09-19-2014, 10:08 PM
Yakfishingfool
Default hinges...
Got a BoT with the flimsy fuzzy covered hinges that have failed. Id like something better for the BoT. Maybe something pinned in? Whats available and recommended?
Yakfishingfool is offline
Old 09-19-2014, 10:27 PM
carpetbagger
I have used Dubro small pinned hinges - good. Requires a slot and glue - I prefer Aleenes Tacky or RC 56 canopy glue. Hinge points also work well but need a thicker surface for drill hole. Also try Blenderm Tape for light weight feathers.
carpetbagger is offline
Old 09-19-2014, 10:43 PM
Yakfishingfool
I was wondering if i could tape the rudder hinge on a bird of time. Might be too big for that.
Old 09-20-2014, 01:46 AM
I've used the "monokote hinge" method on up to .90 glow with no issues... for mild performance aircraft. That is not far removed from the clear packing tape hinges.
Bird of Time has relatively low loads on the hinges.
The #1 cause of failure for the fuzzy "CA hinges" is use of the wrong glue. THIN CA only. Medium and Thick tend to deposit solids in the hinge line which will stretch the hinge material and cause it to fail.
Thinner is better... cheap Dollar Store super glue that doesn't seem to hold anything else together seems to work really well. 6 drops per side of each hinge... it just wicks right in.
Excess gap and oversize hinge slots can also cause problems for the "CA Hinges"
Replacing with other types ... there are many types and just about any can work if installed properly.
Old 09-20-2014, 02:07 AM
Yakfishingfool
These appear to be fuzzy covered white plastic and the previous owner epoxied them in. The fuzz pulled off and the plastic pulled out of the hinge. Will have to look into the tape hinge. It should do fine. Anybody got a tutorial on putting the tape hinges on? Scott
Old 09-20-2014, 02:35 AM
carpetbagger
Default tape
I use Blenderm tape - medical stuff at the drugstore. Mine is 2" wide so I lay a strip on parchment paper (food store has that) and slice it into strips. 1/2" or 3/4" works for me, 1/4" for dinky planes. On the leading edge of the movable surface I cut that to 45 degrees pointy part on top - slide movable to fixed with a 1/64" gap lay strip of tape all the way down. Then you can fold the parts back and lay a strip of tape on opposite side = done. You do this after covering/painting. You have to work around control horns if already installed, no problem.
Monocote (any heat applied covering) works the same, and you can also use the non-heat sticky "trim" sheet as well.
Or you can get some Dacron thread and a needle and do the ol' figure eight sewn hinge!
Old 09-20-2014, 05:26 AM
Wrongway-Feldman
Wrongway-Feldman's Avatar
I've used everything from tape to ca hinges.
My favorite to use is pieces of tie straps. For larger planes just use a straight piece of tie strap. For smaller applications it can get a bit stiff. When that occurs I cut a v grove on one side of the piece to allow easier movement. Works like a charm.
Wrongway-Feldman is offline
Old 09-20-2014, 06:46 AM
If you have old floppy discs - open then up and use the mylar disc inside cut into strips. Simply knife blade slot in each surface, epoxy the strips in.
Old 12-08-2014, 03:47 AM
RV Winkle
Now that is a a good use for those things. 5 1/4 or 3 1/2 or does it matter?
RV Winkle is offline
Old 12-08-2014, 05:39 AM
Any disc !
Old 12-08-2014, 05:42 AM
Any disc !
Yikes
I go back to having used those 8 inch floppy disks! They'd make a lot of hinges.
Old 12-08-2014, 05:51 AM
I still have a PC working that uses discs !! 5.25 and 3.5 .... BUT it is a modern high speed processor job. Just so happens that when the board went on it - the IT service guys replaced board and gear ... plugged in the disc drives as well !!
But just over 1meg is a bit limiting in these days !! I have shoe boxes full of discs from the old days ... and I have to admit a bit of sentimentality in breaking the discs open.
Old 12-08-2014, 06:01 AM
Yup
Just one modern day flash drive can hold 20,000 floppy disks. No wonder the floppy disappeared.
Old 12-08-2014, 06:27 AM
Yup
The advent of OS systems that could handle larger capacity drives and the development of solid state RAM caused the death of floppies. That and USB.
For anyone interested ... there are some old utilities used to exact copy floppies ... ie Copyrighted discs to your own .... that despite having been written to cater for floppy discs will actually copy CD's and DVD's ... exactly.
Unlike USA - EU we are allowed to have own copies as long as we can produce original on demand ... this covers DVD movies, PC stuff .. etc.
Old 12-08-2014, 06:29 AM
:p I still have a working 8088 4,77 mhz machine.
The only way to play original Tetris.
Old 12-08-2014, 07:15 AM
Now you've started it !!
I have a Pc sitting on the side ... an old 486sx ... and reason for that ... my favourite game of all time is :
Wing Commander
I have tried using DosBox, as recc'd on later machines - but still it does not run properly. Wing Commander uses the memory manager utility that basically bypassed the old EMS / XMS crap ... > DOS4G
I'll have to fire her up again ... but suspect having not had her working for quite some time - battery may be dead on the board ...
Old 12-19-2015, 08:03 PM
flypaper 2
flypaper 2's Avatar
I normally use hotglue hinges, but on the smaller ones I use double sided Scotch Tape. The same way that we used to use the cloth hinges where they're glued to the bottom of one surface, through the hinge line to the top of the other surface. The two pieces, one beside the other. Makes a light, tight , no drag hinge.
Gord.
flypaper 2 is offline
Foamies
15
12-02-2013 07:59 AM
Karnsy
10-17-2013 12:40 AM
Base3012
05-12-2013 07:25 PM
Tepid Pilot
Foamies
08-06-2012 06:26 PM
ctslacker
ParkFlyers
01-13-2012 02:14 AM
Quick Reply: hinges...
Page generated in 0.08987 seconds with 13 queries
