My Favorite Digital scale is a... - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Electronic Builders Workshop Discuss how to build motors, ESC's, chargers, mixers, etc here
Old 11-09-2008, 04:53 AM
groundrushesup
groundrushesup's Avatar
Question My Favorite Digital scale is a...
Looking for a good scale I can use to weigh both parts and overall AUW of planes...
What do ya'll use and why?
TIA,
GRU
groundrushesup is offline
Old 11-09-2008, 05:05 AM
TIA,
GRU
Hi to weigh parts I use a letter Scale, non digital, good enough for me, I had it laying around, and to weigh the AUW I use a digital fish scale, works great, and it was Cheap like me Take care, Chellie
http://cgi.ebay.com/DIGITAL-LCD-HANG...1%7C240%3A1318
http://cgi.ebay.com/Vintage-Hansen-P...3286.m20.l1116
Old 11-09-2008, 05:14 AM
groundrushesup
Hey Chellie, thanks as always for your input. I hadn't thought about going the two-scale route - I think I might go with this one for parts and such 'cause it goes from around 3g resolution to a wopping 55lbs!
and look around for a digital hangin' fish scale like that! Thanks for the idears.
GRU
Old 11-09-2008, 05:29 AM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
I use one of these. Does everything I need.
http://cgi.ebay.com/35-Lb-Weighmax-P...QQcmdZViewItem
Grasshopper is offline
Old 11-14-2008, 08:38 PM
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
I use a Rapala digital fishermans scale ,goes to 15 lbs. Shows lbs. and oz. And since you hang the object on a hook it's easy to weigh planes and stuff.
Alpea42 is offline
Old 01-21-2009, 08:48 AM
Wrench66
Ya' need to use mo rudda!
Wrench66's Avatar
I use my Harbor Freight digital scale practically every day. I even have another modded to work with a thrust test stand I made.
Does grams even
http://www.harborfreight.com digi scale
--Ray
Wrench66 is offline
Old 04-16-2009, 11:20 PM
Nitro Blast
Nitro Blast's Avatar
Ive been using this Berkley Digital scale for over 10 years now, and the bugger still has the same freaking battery in it!
Under 20 bux at WallyWorld, and it also works as a thrust meter!
I've also been seen carrying the digital bathroom scale out to the shop on occasion for the over 50 lb stuff, and I've got a small digital postal scale for super light stuff, the fishing scale is clearly the most used for me.
Nitro Blast is offline
Old 04-16-2009, 11:48 PM
vax6335
Crazy 'bout Bees
vax6335's Avatar
I got a cheap little scale from Circuit CIty's website when they were still in business a long time ago. I weighed a motor with it once and confronted the manufacturer about it weighing more than what it was advertised at. They accused me of having a cheap out of whack scale and that's what was wrong.
Took the motor to work and weight it on an Air Force calibrated scale (don't think those are wrong when you're dealing with people's lives)....... same weight.
vax6335 is offline
Old 01-03-2010, 04:34 PM
Modifier
"Bank and yank"
Been hunting around for a small scale that would measure small stuff as well as overall weights.
Harbor freight has a cheap penny scale that I have been looking at.
http://www.harborfreight.com/cpi/cta...emnumber=93543
Looking for something small and compact that could go into the flight box, then I would need something for the build table to handle a bit more weight, and once again Harbor Freight has the larger one that Wrench66 posted.
http://www.harborfreight.com/cpi/cta...emnumber=95364
Any suggestions from the crowd on a good do-all scale??
Not stuck on Harbor Freight for any reason, just found the small scale there.
Modifier is offline
Old 07-26-2012, 12:20 AM
Mr.GFC
Mr.GFC's Avatar
Default Digital scales
I was actually able to build a small test stand for static thrust measuring for my digital scale.
Static Thrust
Mr.GFC is offline
Old 09-25-2013, 06:21 PM
E-Challenged
E-Challenged's Avatar
I have a cheap Harbor Fright digital scale that measures up to 11 pounds, seems accurate enough for modelling work. Has power supply and will also run on batteries
E-Challenged is offline
Old 07-10-2014, 12:01 PM
MrBrook
Post lover
MrBrook's Avatar
I am using a Rapala Digital Scale. Quite happy with the results as it shows measurements both in lbs ans oz, having a water resistant design, Has memory to have the total of weights and much more.
As being a hanging scale with a hook it is too easy to weigh on it..!
MrBrook is offline
Old 07-10-2014, 04:34 PM
Modifier
"Bank and yank"
Wow,,4 yrs ago. time literally flies.
Bought both Harbor freights I linked to above. Still clicking along with both of them. The bigger one has seen double duty with my Pyro chems and have matched it as far as repeatability and low count measurements with my buddy's $950 uber spendy chemical scale of the same style and design.
Modifier is offline
Old 07-10-2014, 04:49 PM
A standard scale in one of my labs would set you back over $5000 .... and they are contained within a cabinet to avoid air movement while measuring .. have to be calibrated regularly ...
My $5 over counter scale was within reasonable tolerance of the $5000 dollar scale ! But of course my $5 scale cannot go to the precision of the lab one.
Todays electronics give extreme accuracy that was unheard of in days of dial analogue ... with prices that are just so cheap as to be ridiculous.
Old 03-17-2017, 05:40 AM
mayakenvin
Hi, i recommend etekcity digital scale as i have used it for almost 2 years without any problem. You can go its amazon store to buy.
mayakenvin is offline
Old 03-17-2017, 02:52 PM
Henry Sistrunk
Henry Sistrunk's Avatar
Surely he has bought one by now. That post was 2008.
Henry Sistrunk is offline
Old 03-17-2017, 06:32 PM
Past President of PSSF
I could not find a scale that would give me the accuracy at the low end around 1-16 oz, and be able to weigh the entire plane.
I bought a small scale that maxes out at 1lb, but it has very good resolution at light weight. I use it to check small items and to mix epoxy in the correct ratios. West Systems Epoxy mixes at a 4.6 to 1 ratio.
I just put a small paper cup on the scale and put in the correct amounts. If you use fillers in epoxy, this is the only way to get a consistent mixture. You can't just guess at it.
I also have this scale
http://www.ebay.com/itm/USSHIP-Porta...AAAOSwd4tUKeAk
I can weigh anything up to 88lbs. I hang my planes from the ceiling so most of them have their own cradle made from strong cord, this make it very easy to weigh the entire plane. Or just weigh sections and add it up.
Both are small and easy to carry.
I also tie a loop around the tail of an airplane and tie the luggage scale to a post, for thrust.
Wildflyer is online now
Old 03-17-2017, 07:50 PM
My Kitchen digital scales ...
0 - 2kg at 1gr graduation
0 - 5kg at 2gr graduation.
Good enough for me ...
My hanging fish digital I use for thrust tests and overall model weights is up to 40kg but at 10gr graduation.
Gigawatter
08-19-2008 12:45 AM
edfire
Off Topic Chit Chat
16
11-10-2007 07:26 AM
Gnascher
ParkFlyers
11
07-20-2007 10:14 PM
Skypoet
04-26-2007 05:27 PM
Steve Nolan (eBird)
05-21-2006 05:46 AM
Quick Reply: My Favorite Digital scale is a...
Page generated in 0.08473 seconds with 13 queries
