"5ezp" f-104 starfighter - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 10-12-2017, 05:16 PM
Bobdaeronort
Bobdaeronort
Default "5ezp" f-104 starfighter
So taking what I've learned from the recent MiG-21, F-100 and Su-22m Fitter builds I've begun a design of the F-104 STARFIGHTER. She is 48" long with an anhedral wingspan of 24" (just a bit longer than the prototype) She will be powered with a SMJv2 spinning a 6x5.5 "Prop-Inna-Box" and be controlled with ailerons and a flying 'T' elevator.
It's the same size and power system as my MiG-21 model so it should fly similarly. I think though that it may be faster because it is more streamlined than the MiG-21.
Also, I want to revisit the F-101 VOODOO with the same 'T' tail solution I'm using for the Starfighter. I found a 3/8" dia. nylon plumbing 'T' which just snuggly accepts a 5.3mm CR. for the control surface pivot and another perpendicular to it to imbed in the rudder. My previous attempts at a "T" tail failed.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Bobdaeronort is offline
Old 10-13-2017, 02:38 PM
Bobdaeronort
Bobdaeronort
https://youtu.be/u6x3ZBefzDs
Old 10-15-2017, 05:08 PM
Bobdaeronort
Bobdaeronort
https://youtu.be/Z8Fa5Td126c
Old 10-22-2017, 11:05 PM
Bobdaeronort
Bobdaeronort
https://youtu.be/ZhNTmCrm0ZE
Old 10-23-2017, 02:47 AM
Bobdaeronort
Bobdaeronort
Now if I can just get the hang of flying her
https://youtu.be/WlgUhTKqtPM
Old 10-24-2017, 03:02 AM
Bobdaeronort
Bobdaeronort
Notes on flying the "5EZP" F-104 Starfighter:
1. Speed. She loves to go fast. I was trying to trim her at half throttle and realized that it wasn't that her trim was off it was that her stubby wings were nearly tip-stalling at the lower speed. So I throttled up and her twitchy roll quieted right down.
2. Just like the prototype you have to think way out ahead of her.
She is an intense 4-5 minutes of flight. This is not a plane that you can take a thumb break with. You have to stay on her and ahead of her or you will lose it. She is most unforgiving.
3. Once you get the feel of her, She is a blast to fly.
4. I may try scaling her up 1.15% so I can fit a 7x5 prop in the tail box for more thrust.This worked well with my F-100. So well I have now crashed both of my 1.15% versions. Or scale her down to fit a 70mm EDF on one of my 4S Li-Pos.
Old 10-06-2019, 03:41 AM
Bobdaeronort
Bobdaeronort
Bobdaeronort
Bobdaeronort
Old 10-06-2019, 08:38 PM
Bobdaeronort
Bobdaeronort
Fixed the droopy fuse:
Old 10-16-2019, 01:47 AM
Bobdaeronort
Bobdaeronort
Old 10-16-2019, 05:23 AM
ROCKETCHRIS
You have incredible talent and perseverance Mr. Daeronort. To design , build and fly an f104 starfighter with no gyro is about as good as it gets, especially knowing how hard you've worked to perfect the design over years. You're an inspiration
ROCKETCHRIS is offline
Old 10-20-2019, 02:37 PM
Bobdaeronort
Bobdaeronort
Thanks Chris!
It was sure a challenge.
Once she is dialed in though she is fun to fly.
Bobdaeronort
Pusher Park Jets
8
10-15-2017 06:59 PM
Bobdaeronort
Pusher Park Jets
11
10-01-2017 04:10 PM
Bobdaeronort
Pusher Park Jets
11
06-14-2016 12:02 AM
Bobdaeronort
Pusher Park Jets
25
07-28-2015 01:58 AM
Bobdaeronort
Pusher Park Jets
03-13-2015 04:28 AM
Quick Reply: "5ezp" f-104 starfighter
Page generated in 0.12505 seconds with 22 queries
