Pattern aircraft Discuss electric powered pattern aircraft in here
Control throws for a newbie?
Old 01-13-2006, 03:11 AM
Twmaster
Registered User
Twmaster's Avatar
Default Control throws for a newbie?
Since I've never flown a pattern bird before I'd like to get some kind of idea what I should set my control throws to as a beginning point. I have a used Fliton Flubber as my newbie birdie.
-or-
Would I be better off just dialing the throws down on my TX from the start?
Twmaster is offline
Old 02-13-2006, 04:48 AM
Twmaster
Registered User
Twmaster's Avatar
Nobody has any wisdom to offer on this subject?
Twmaster is offline
Old 03-31-2006, 05:37 AM
Kyle G.
Grace Under Pressure
Kyle G.'s Avatar
Just keep the throws low on the first flight. If you've got dual rates, use them incase the throws are too low. Not knowing much about the plane, its hard to tell where the throws should be.
Kyle G. is offline
Old 03-31-2006, 06:18 PM
gdhampton
Doesn't the manual state what the throws should be? I agree with Kyle G., use low rates and exponential if you have it. Not familiar with this plane either. If the ailerons are full length keep the throws under 3/8" to start with. Post more info and others will probably add their thoughts.
gdhampton is offline
Old 05-10-2006, 08:01 AM
Ron
I set the ailerons so that you can get about 3 rolls in five seconds.
Elevators set for no more than 15 degrees travel each way on high rates.... this gives plenty of authority for pattern type flying. I also use as much rudder as I can comfortably handle, which I adjust as I am doing trim flights. When I first setup a " pattern" model, I was amazed at how little control surface deflection you need to have.
Ron is offline
Old 05-10-2006, 06:28 PM
gdhampton
Sounds like you have it wired... nice job! Enjoy it.
Old 05-11-2006, 09:48 PM
Twmaster
Registered User
Twmaster's Avatar
Thanks for the advice gang. I'm going to get working on this used Flubber I have here.
Twmaster is offline
intruderwithin
01-28-2009 12:53 PM
nheilweil
07-26-2007 12:34 AM
rick88ss
Foamies
06-22-2007 08:54 AM
drzoidberg
01-16-2007 12:35 AM
Rsiaviation
Warbird Electrics
11-21-2006 02:17 AM
Quick Reply: Control throws for a newbie?
Page generated in 0.10094 seconds with 13 queries
