Pattern aircraft Discuss electric powered pattern aircraft in here
Wanted Small Electric Pattern Plane
Old 10-24-2010, 06:18 PM
dunwrkn
Default Wanted Small Electric Pattern Plane
I am looking for an Eflite Brio, or Fliton Quite Storm.
Airframe or RTF.
Thank you
dunwrkn is offline
Old 10-25-2010, 07:11 AM
dumpsterjay
It's all in the thumbs
dumpsterjay's Avatar
You might want to look in the airplane for sale classifieds as neither one of those models have been available for a while.
J
dumpsterjay is offline
Old 12-10-2010, 06:43 PM
hillbille
hillbille's Avatar
An excellent alternative choice might be a GWS Formosa. Usually can be had under $40 for a NPS version and will fly pattern extremely well.
Hillbille
hillbille is offline
Old 12-11-2010, 02:27 AM
Airframe or RTF.
Thank you
Or checkout the late 1990's Electrostreak. I've owned three of them, still got two of them, sold the last one. This model would be great with an appropriate brushless motor.
http://www.hobbyauthority.com/produc...3&cat=9&page=1
Old 02-24-2013, 07:49 AM
bacibear
I have an Eflite Leader 480. The recommended power system seemed a bit weak, so my setup is: A Suppo 2820/6 1000k motor (550 watts max), a HobbyWing Pentium 60 ESC, 4 cell 2200 Mah lipo and an APC 10x7 prop. With this setup, the plane weighs in at 48 Ounces. It has enough wing area to carry this fairly easily, with a stall speed just under
20 MPH. The plane both tracks and performs pattern well. It easily does unlimited vertical and is quite fast - I average about 1/2 throttle for most flying. My timer is set for a five minute flight, and the batteries are always over 20% upon landing, with the motor only slightly warm to the touch.
bacibear is offline
Old 04-02-2013, 09:39 PM
http://www.wattflyer.com/forums/showthread.php?t=70266
Read that post...
Low cost and amazing. $175 (shipped) aircraft with motor and servos.
Then go to Nitroplaness.com get the Dynam 40 amp ESC ($10 GOOD ESC!) and a pair of 4S 4000 mah SkyLiPo (20 c is plenty) for about $90 shipped.
Add TX and RX and you can be in the air in under 2 hours from when it all arrives.
Old 07-03-2013, 05:47 AM
RZielin
Default Or this one
http://www.aero-works.net/store/detail.aspx?ID=256
RZielin is offline
Old 07-20-2013, 02:02 AM
Or this one: http://www.headsuphobby.com/GWS-Formosa-II-GWS116.htm
$50.00 plus servos, motor,escand better LG . Check out the Formosa II thread here: http://www.wattflyer.com/forums/show...ght=Formosa+II
Doesn't get any cheaper than this. Flys great !
-Hawk
Old 12-08-2013, 05:17 PM
I just bought the Accipiter Badius $54.22 with free shipping from Banggood .. clone of the Formosa that I read is no longer made ...
Page generated in 0.10020 seconds with 9 queries
