Flaperons with a Y harness
Old 01-18-2016, 03:38 PM
grant22
Default Flaperons with a Y harness
Is it not possible to do 'flaps' with a Y harness? Do I need to remove it and plug one aileron into its own channel? If so, what's the standard way of doing this?
Right or left into 'aileron' in the rx?
Remaining aileron into ? In the rx?
Also, on an easy glider, does anyone know if flaps are pointing up or down on this model? It seems the directions show 'up' but I've always seen flaps pointing down. What am I missing here?
Thx for any help
grant22 is offline
Old 01-18-2016, 03:48 PM
dereckbc
You cannot use a "Y" harness. You will need to plug each aileron into a separate channel. I might have this reversed but using a Spektrum TX/RX Left Aileron plugs into ch2 (aileron channel) and Right Aileron into ch6 aux channel. Not a glider pilot but I think down is flaps, and up is spoilers.
dereckbc is offline
Old 01-18-2016, 04:47 PM
Have to be on separate channels like Dereck said. on spekkies it's Aileron and Aux1, then you have to tell the transmitter the proper wing type. And yeah, flaps down spoilers up.
firemanbill is online now
Old 01-18-2016, 05:22 PM
grant22
Thx gents
grant22 is offline
Old 01-18-2016, 05:55 PM
crxmanpat's Avatar
Or get, or make, a reversed servo. If you are good with soldering and have a fine tip for your iron, reversing a servo is actually pretty easy to do. Then you can hook up both servos on a Y and only use one channel. This video can help:
https://www.youtube.com/watch?v=4n1ec2w21pA
I've done this several times and it works perfectly.
crxmanpat is online now
Old 01-18-2016, 06:11 PM
I don't think will work on flaperons will it. If you did that the aileron function wouldn't work.
Old 01-18-2016, 06:16 PM
Correct.
With a Y you either get Ailerons or flaps. Not Flaperon mix.
Old 01-18-2016, 06:52 PM
grant22
Took the EasyGlider Electric out for its maiden today. Had the typical trim adjustments, but it flew fine, although its power is barely adequate.
This is the first time I've tried flaps (spoilers in this case). I'm glad I tried it up hi first.
I got to a landing speed turned on the spoilers and it basically near stalled and was in a pretty quick dive. I couldn't tell if it stalled first then dove......but from what I can tell my speed was near stall and the elevator mixed in put it into a dive.
So I'll play with that more later.
I can see why you almost need this function. This thing just wants to keep flying, so getting it down at a safe speed is pretty tough. But I did it without using the spoilers.
grant22 is offline
Old 01-18-2016, 07:01 PM
One trick for getting a sailplane down is to put it so the wing is near vertical and hold full elevator. Some you have to hold rudder/aileron to prevent them rolling back level on their own.
For a 2 ch rudder-elevator sailplane this is the best way to get down fast. Straight diving has been known to rip wings off.
You can roll it inverted and use that to come down also. With the wing lifting downward you can bring it down without building excess airspeed. But this one is easy to accidentally build up airspeed and not realize it.
Old 01-18-2016, 07:14 PM
crxmanpat's Avatar
Ha ha, yeah. I was thinking flaps, not flaperons.
weedsnager
12-28-2014 04:53 AM
rajkojus
07-11-2014 05:45 PM
Rbwindover
02-15-2012 02:07 AM
bobskinner
05-10-2011 04:43 AM
Alaska
02-02-2011 03:33 AM
Quick Reply: Flaperons with a Y harness
Page generated in 0.12541 seconds with 13 queries
