Dx9 Flaperons, with gyro
Old 12-28-2014, 04:10 AM
weedsnager
Default Dx9 Flaperons, with gyro
Is it possible to set up flaperons with the Eagle A3-L gyro? I'd like to set it up with an 800 mm plane, Ar610 transmitter, and a Dx9 radio
weedsnager is offline
Old 12-28-2014, 04:53 AM
Yes and no...
You can either have just one aileron affected by the 3-axis gyro (which can work since many pylon racers only use one aileron)
Or you can use a separate mixer device AFTER the gyro to mix flaps to the ailerons.
The issue is that the gyro being after the RX will not be able to send its signal to both ailerons in flaperon mode when using the computer radio to do the mixing.
14
12-22-2014 03:57 PM
04-29-2014 03:45 AM
GunnyJeeves
3D Flying
12
09-15-2013 03:31 AM
General RC E-Heli Talk
02-20-2013 01:40 PM
09-13-2011 06:58 AM
Quick Reply: Dx9 Flaperons, with gyro
Page generated in 0.11261 seconds with 13 queries
