Timber prop for turbo timber
Old 09-24-2019, 07:55 PM
jangodog
jangodog's Avatar
Default Timber prop for turbo timber
Hi. can i use this one when putting af two blade prop on my turbo timber?
https://holte-modelhobby.dk/shop/96-...pinner-timber/
jangodog is offline
Old 09-25-2019, 06:32 AM
Past President of PSSF
That link shows a spinner, not a prop.
If you are thinking of a 3 or 4 blade prop, it should work fine if you use the right size.
I would recommend using a wattmeter to make sure you are getting the correct power from the prop without overloading.
Wildflyer is offline
Old 09-25-2019, 09:19 AM
Are you asking : Can you use the spinner ?
Why not ? Spinner does not care about the prop - as long as blade count and size is correct - you can use any you like.
Old 09-25-2019, 10:15 AM
jangodog
jangodog's Avatar
My bad. What i mean is about the right size for the spinner on my Turbo timber. Guess the original Timber and my Turbo timber use the same prop size. Iíll get the one from link then. What is the correct output/wattage for TT? I have a HK wattmeter i can
use
jangodog is offline
Old 09-25-2019, 10:18 AM
jangodog
jangodog's Avatar
Hi. Guess your right. Iíll get the one from my link. Thankís.
jangodog is offline
Old 09-26-2019, 03:23 AM
E-Flite rates the BL 10 motor having a max of 450 watts.
I have learned to check the watts every time I use a prop that is different from the last one in any way, or when I change to a different battery.
I had one plane that flew great with a certain brand of a 11x7 prop. Some other 11x7 props only delivered 1/2 the power.
Then I changed to a different brand battery. The new battery was a much better one than I had before. The plane went nuts, the new battery gave me twice the power output of the old ones. Now I had to down size the prop.
If I didn't have a wattmeter, I would have smoked an expensive motor.
Old 09-26-2019, 09:55 AM
jangodog
jangodog's Avatar
So the wattage i have now with current/original 3 blade must be almost the same with the new 2 blade
prop? The two blade prop i got is for the old Timber.
jangodog is offline
Old 09-26-2019, 07:03 PM
Yes, if you have too little wattage from the prop, the plane may not fly well at all.
If you have too much it's bad for the motor.
There are many other factors involved in the "perfect" prop. Too little pitch and the plane may not get to a good flying speed, and of course too much doesn't work well at all except in a racing plane.
Good luck.
Old 09-26-2019, 09:52 PM
jangodog
jangodog's Avatar
Good luck.
Okayí ill run wattage test with both props before next take off Thankís.
jangodog is offline
Old 09-27-2019, 09:08 AM
Question ....
What numbers are on the original prop blades near the hub ? Usually the prop diameter / pitch are on the blades ....
Old 09-27-2019, 08:03 PM
jangodog
jangodog's Avatar
11 X 7-3 says on prop.
jangodog is offline
Old 09-27-2019, 09:17 PM
Which means :
11" diameter
7" pitch
3 blades
Old 09-28-2019, 03:32 PM
jangodog
jangodog's Avatar
Which means :
11" diameter
7" pitch
3 blades
Exactly
jangodog is offline
Old 09-30-2019, 03:25 AM
hoosier37
hoosier37's Avatar
I use a 12X6e APC prop and a spinner from the Timber X. Prop recommended in the RCGroups thread for the turbo timber. Works great.
hoosier37 is offline
Old 09-30-2019, 09:50 AM
jangodog
jangodog's Avatar
Great info my friend
jangodog is offline
Old 09-30-2019, 10:25 AM
It makes sense ... 12" gives more thrust, 6" gives less speed but better throttle range.... there's also likely a slight increase in RPM.
Its a common swap on Glow 60's as well ..... 11x7 on a faster machine ... 12x6 on a biplane etc.
Old 09-30-2019, 01:52 PM
jangodog
jangodog's Avatar
I had a crash landing a couple of meters from ground. Hope the engine works fine. Nothing to do with the prop though. Cowl broke and i ordered a new one
jangodog is offline
Old 11-12-2019, 10:25 PM
xSOSxHawkens
Timber x and timber turbo are almost the same on power, if you want 2 blades look at the 13x4e prop, which is stock for a tomber x.
Both planes use a 50a esc. Turbo has an 800kv motor with high prop pitch for high speed (turbo speed) while the X uses a 900kv motor with less pitch for faster mid speed response.
xSOSxHawkens is offline
Old 11-12-2019, 10:52 PM
jangodog
jangodog's Avatar
I actuelley found the original prop for the regular
timber and it gives my turbo timber a little more speed/draft. Thankís for reply.
jangodog is offline
admin
11-14-2021 07:12 AM
11-02-2021 02:03 PM
05-28-2020 10:50 PM
Alabama Flying Dude
Pusher Park Jets
05-19-2012 05:13 PM
11-26-2011 11:09 PM
Quick Reply: Timber prop for turbo timber
Page generated in 0.14759 seconds with 12 queries
