Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight >
Hobby Express discussion Hobby Express Support, information and discussion.
Old 02-21-2009, 11:22 PM   #1
Flyboone
twitter.com/flyboone
Flyboone's Avatar
Default Eurofighter Tiger Jet
Eurofighter Tiger Edition RTF Jet
Eurofighter Tiger Edition ARF Jet
29-1/8" wingspan, 42" long, 350 sq. in. wing area, 30 oz. flying weight. This colorful pre-painted jet has all the main assemblies pre-built. Assembly to flight ready status takes only an hour or two. Two 64mm fans driven by two Outrunner brushless motors power jet. The two speed controls are 25 amps each and are pre-wired and installed, ready to plug into the supplied 2200 mAh 3-cell lipo battery. Battery access is under the canopy. Canopy is held in place by magnets, as is the upper section behind the canopy, providing access to the speed controls. Fans and motors can be accessed through a removable panel on the bottom of the fuselage. ARF version is ready for you to install your 4 channel receiver (delta mixing required). A balance charger for the lithium battery is included. The 3 servos are pre-installed and all control surfaces are pre-hinged with the control horns installed. Jet can be flown with the included landing gear and steerable nose wheel, or the gear can be quickly removed for hand launching and belly landing. Flight times are in excess of 5 minutes. The twin fans provide lots of thrust for strong climbs and a high top speed. Rolls, loops and inverted flight are a breeze and the delta wing really slows down well for soft, slow landings. Photo illustrated building instructions with CG location clearly marked will get you from the box and into the air quickly.
For more information click HERE
Use this thread to discuss any and all things related to Eurofighter Tiger Jet
Flyboone is offline
Old 02-23-2009, 06:01 PM   #2
Mike Parsons
Penguins still can't fly
Mike Parsons's Avatar
Club: www.electricdrones.com
Friends: (25)
Those are Hot hot hot!!!!
Proud Supporter of
Atlantahobby.com
ExtremeFlightrc
Mike Parsons is offline
Old 02-23-2009, 06:22 PM   #3
Cdr. Instigator
Pimp My Plane
Cdr. Instigator's Avatar
Club: AMA number is: 934723
Nice.. That almost gave me chills !!!
Cdr. Instigator is offline
Old 11-17-2009, 03:01 AM   #4
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
Friends: (25)
anyone know the CG location? I have one of these we're converting to a pusher... they didn't sell them anymore, so we are assembleing them by parts...
THE B-2 Worlds most expensive airplane.
Alpea42 is offline
Old 11-20-2009, 01:33 AM   #5
Alpea42
Alpea42's Avatar
Friends: (25)
It flew great as a pusher. Got the AUW down to 28 oz. with a Turnigy 2217-16 23A motor =450 a 1300ma 20c 4s Zippy Li-Po on a 7x5 APC E prop .... It's light enough to fly slow and although it doesn't quite have verticle thrust it's plenty fast for my liking. Maidened it Monday and put 4 flights on it then put 5 more on it yesterday. I get 8 min. flight times on the 1300ma battery . If it was a twin 64mm EDF I'ld be lucky to get 4 min flights with a 2200 battery. I ended up with a little down thrust on the motor stick so I made the nose gear wire 3/8ths " longer to help it rotate.It started tail heavy but we kept moving the battery forward untill it's a full length forward from where we started.
ID:	113665   Click image for larger version
ID:	113666   Click image for larger version
ID:	113667   Click image for larger version
ID:	113668   Click image for larger version
ID:	113670   Click image for larger version
ID:	113671   Click image for larger version
ID:	113672   Click image for larger version
Alpea42 is offline
Old 11-23-2009, 05:26 AM   #6
Alpea42
Alpea42's Avatar
Friends: (25)
It excells as a pusher
Alpea42 is offline
EDF Jet Factory Sport Jet!!! Crash Test Dummy Electric Ducted Fan Jets 107 02-26-2013 08:20 PM
X-Flight EuroFighter Typhoon 2 EDF Build Thread FresnoJay Electric Ducted Fan Jets 43 11-23-2009 05:50 AM
Bugatti Veyron vs Eurofighter firemanbill Off Topic Chit Chat 5 04-08-2008 07:16 AM
Eurofighter Kosh Video Parking lot 1 09-17-2007 11:43 PM
Tiger in the Trelis Crashalott Foamies 2 07-24-2007 11:00 PM
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
Page generated in 0.11306 seconds with 23 queries
