Trimming Question
Old 05-30-2007, 12:47 AM
cassat
Default Trimming Question
Hello all,
So now that I have my wing flying , I need to fine trim it since it is doing really sloppy rolls and loops.
There is a teqhnique something like ....pull a slow loop and see which wing drops?? Any help here is welcomed.
Cassat
cassat is offline
Old 05-30-2007, 04:24 AM
lmopar69
Gravity Stinks!!
lmopar69's Avatar
If its acting funny in rolls and loops, first thing I would do is check the control throws. Make sure the elevons go up the same amount and down the same amount with "elevator" input, and make sure they go the same amount with "aileron" input. If the problem is there, you should see it and either be able to mechanically sort it out, or if you have a computer radio, you can change the ATV for each control movement.
If the problem isnt in the throws, it could be a cg issue. Try moving the cg. I would go back in 1/8th inch increments until it gets a little "too sensative" then move it forward the the last spot it flew "right".
Any thing else after those two are done could be a warp or some other structural issue.
I may not be 100% text book correct on "my method" but it should work out for you. Just takes some time and testing is all.
Hope this helps.. let us know.
Laine
lmopar69 is offline
Old 05-30-2007, 04:36 AM
cassat
Default Dialing
Ok. Just testing you Laine to see if you made it back from that last flight ok. Yes, I had 5 % aileron differential dialed in to the computer. I will remove it and test again in a bit here. Will let you know what I find.
Cassat
cassat is offline
Old 05-30-2007, 04:44 AM
lmopar69
Gravity Stinks!!
lmopar69's Avatar
lol... Im good bud.
Sounds like a plan.
Laine
lmopar69 is offline
crx_ef8
01-12-2008 06:43 AM
bradas
9
01-08-2008 12:19 AM
manblue
20
08-25-2007 04:17 AM
Ribcracker
11-28-2006 04:23 AM
luisfc1972
03-29-2006 01:53 AM
Quick Reply: Trimming Question
Page generated in 0.08735 seconds with 13 queries
