Electronic Builders Workshop Discuss how to build motors, ESC's, chargers, mixers, etc here
JST connector amp rating
Old 04-04-2018, 05:08 PM
Walt Thyng
Walt
Walt Thyng's Avatar
Default JST connector amp rating
How many amps can a JST connector carry? Can I use one to install a 5 amp max external BEC?
TIA
Walt Thyng is offline
Old 04-04-2018, 05:26 PM
Past President of PSSF
According to the specs on Wikipedia, they are rated for 3 amps.
https://en.wikipedia.org/wiki/JST_connector
I know many people use them at much higher current levels, but at some point they will start getting hot.
Since your average current would be well below 3 amps it should work okay, but if you had something that pulled a steady 5 amps, things might start getting warm.
I use XT30's on small stuff, I know it is 4 times larger but it is still small enough for me. Plus it can carry 30 amps, probably a short term rating, I would not use it for my home 30 amp dryer circuit.
Wildflyer is offline
Old 04-04-2018, 06:01 PM
Walt Thyng
Walt
Walt Thyng's Avatar
Thanks Dave that just what I needed to know. My BEC will be driving a RX and 4 standard SX. When I test the set-up I'll give the SX a workout and then check the JST for heat.
Old 04-04-2018, 09:34 PM
You won't overheat it just powering the Rx and servos.
Many small lipo's come with a JST, if they are used for powering a ESC and motor, then things could get hot. A relatively small 120 watt motor would pull around 10 amps on a 2 cell battery.
Different equipment, but one time I had my 120vac electric chainsaw's plug, absolutely weld itself into the female socket of my heavy duty extension cord.
I had to cut both cords and put new plugs on them.
Everything was acting normal until I tried to unplug the cord.
120 vac cord connectors are only rated for 15 amps.
Chainsaw pulled about 13 amps, but it was enough to weld the parts together.
Old 04-05-2018, 09:35 AM
hayofstacks
hayofstacks's Avatar
I'd call about 10 amps the limit. I had about 140 watts on a slow stick with my first rc setup. I used a 3 cell eflight Lipo from a helicopter with a jst connector on it.
hayofstacks is offline
Gordone
04-10-2016 04:07 PM
Batteries & Chargers
10
11-10-2012 06:01 AM
11
09-06-2011 05:19 AM
shaf
12-23-2010 03:02 PM
Quick Reply: JST connector amp rating
Page generated in 0.09879 seconds with 12 queries
