Multi Motor help
Old 01-15-2012, 05:52 PM
hiflyerk
Default Multi Motor help
I have this foam B29 that was given to me, it has 4 motors that currently use differental power to control the plane. I want to modify the equipment, add a new esc's. What is best way to determine the esc capicity needed. Should I go with 1 esc or 2?
What type of battey power? Should I change to motors out to brushless?
Span is aprox 42" overall weight is 11oz
Name:	2011-12-29 15.14.11.jpg
hiflyerk is offline
Old 01-16-2012, 01:58 PM
Walt Thyng
Walt
Walt Thyng's Avatar
Why do you need a new esc in order to go to 2.4? As long as the rx plug fits, frequency shouldn't make any difference.
Walt
Walt Thyng is offline
Old 01-16-2012, 06:10 PM
cliffh
I didn't see anything about changing to 2.4
Anyhow, with BRUSHED motors, you only need one esc. With BRUSHLESS you need a separate esc for each motor. Disclaimer: some people can sometimes get away with a single esc for 2 brushless motors, but it is not recommended and usually will not work correctly.
The best way to determine the correct size esc is to use a wattmeter and briefly power the motors up to determine the power draw. Actually though, those are small motors and I'm sure a single brushed 10 amp esc will be fine.
Wire the motors in parallel, not series.
Cliff
cliffh is offline
Old 01-16-2012, 06:50 PM
hiflyerk
Any suggestion as to size of ESC needed.
4 motors
hiflyerk is offline
Old 01-16-2012, 07:32 PM
cliffh
I'm sure a 10amp esc would work fine for those small motors in the photo....all 4 of them. A larger esc could also be used with just a penalty in weight.
But that is just an educated quess. My GWS 4 motor C130 draws 8 amps with a 2S lipo. My 2 motor GWS BN2 Islander with much larger motors draws 10 amps with a 2S lipo.
Your motors look very small. To be safe, you should beg or borrow a Wattmeter to check the current draw or just purchase a 25 amp esc to be absolutely safe.
At any rate, with brushed motors, one esc is fine.
Cliff
cliffh is offline
Old 01-16-2012, 09:45 PM
cliffh
Here is a 20 amp brushed esc for less than $5 .... unfortunatly they are backordered right now. Are you in a hurry?
http://www.hobbyking.com/hobbyking/s...idProduct=9090
cliffh is offline
Old 01-17-2012, 03:20 PM
cliffh
I'm going to guess that this is the airplane you have. Here is a link to lots of information and tips for you.
http://www.rcgroups.com/forums/showthread.php?t=284067
Cliff
cliffh is offline
n3m1s1s
Beginners - Helis
11-14-2011 10:09 AM
KeninAZ
Batteries & Chargers
21
10-27-2011 03:25 AM
PKNEC
FMA Direct
08-09-2011 10:15 PM
ehirobo.com
04-12-2011 08:59 AM
ehirobo.com
Standard & Large E-Heli Talk
02-24-2011 06:51 AM
Quick Reply: Multi Motor help
Page generated in 0.10834 seconds with 14 queries
