Old 06-29-2012, 06:05 PM
Bruce Harding
Default New Member
Guys,
I am a new Member to WattFlyer. I have been building and flying giant scale warbirds for years. I bought an ESM PC9 and decided to install an AXI 534514HD for power. I am controlling it with a Turnigy Superbrain 100A esc and two Gens 5300 18.5v battery packs. The Turnigy did not come with any instructions. I bought the programmer also. It has some instructions but not much. I have flown the smaller electrics but this programmer has alot more programming ability.
One thing that is messing me up is the programmer is asking for a parameter of either 8kw, 10kw, 12kw, or 14kw. I am at a loss with what it is asking.
Also I have the battery leads directly plugged into the batteries with no switch. I have to take the airplane apart everytime I want shut down the plane and to charge the batteries. What kind of switch would work to turn off the power to the esc?
Many Thanks
Bruce
Bruce Harding is offline
Old 06-30-2012, 12:20 AM
hayofstacks
hayofstacks's Avatar
Can't help as I've only delt with parkflyers...
But welcome to the forum!
hayofstacks is offline
Old 06-30-2012, 04:59 PM
Walt Thyng
Walt
Walt Thyng's Avatar
Default newbie questions
the 8 - 14 numbers refer to the pulse width (PW) at which the ESC is working. Most use either the factory default setting or 8. Going to a higher number gives more precise ESC response, but uses more power. Typically on competition pilots play with this number.
If you are using Lipos you should not charge them in the plane as a mistake could destroy it.
For saftey's sake most use an "arming plug." These go between the battery and the ESC, usually on the red lead. There are commercially available plugs or you can make your own using ths same style connector as on your batts and ESC. Basically an arming plug is a jumper that completes the circuit.
Hope this helps.
Walt
Walt Thyng is offline
Old 06-30-2012, 09:36 PM
pd1
Still Learning
pd1's Avatar
Here's a source for the arming plug:
\http://www.maxxprod.com/mpi/mpi-21.h...racle%20Switch
6972 Arming Switch, with Ultra Dean Plugs & AWG12 wires
6982 Arming Switch, with Power Poles & AWG12 wires, 45A contacts
pd1 is offline
Old 07-01-2012, 01:14 AM
Welcome to the site!
RCJeff
07-21-2017 12:58 AM
03-30-2012 04:58 AM
Bo90
10-28-2011 09:49 AM
AndrewQLD
01-10-2011 01:33 PM
Quick Reply: New Member
Page generated in 0.11036 seconds with 15 queries
