Which motor to upgrade to on Durafly/Banana Hobby T28?
Old 03-31-2022, 08:31 PM
socalrcflyer
Default Which motor to upgrade to on Durafly/Banana Hobby T28?
Hi,
Which motor should I upgrade to on my Banana Hobby T28 1100mm aircraft? I want to fly faster, and also have a good low throttle cruise amperage draw. Thanks!
https://www.bananahobby.com/7-ch-bli...plane-pnp.html
socalrcflyer is offline
Old 03-31-2022, 11:30 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Does your motor (battery, controller) have headroom left? I.e. can your motor handle more power and current than it has to do now with current setup?
Then you could increase pitch and/or prop-diameter and/or voltage.
Each of these changes results in an increase in current and power drawn (no effect on motor's capabilities). Use small increments and always measure because the increases are very disproportional.
Current drawn is proportional to pitch voltage≤ Kv≥ and diameter⁴
On the other hand ...
It is a good practice to have some headroom built in. Motor runs cooler, slightly more efficient too, and you have some leeway should things go south a bit.
About derating motors, controllers, batteries, electronics in general:
ron_van_sommeren is offline
Old 04-03-2022, 12:40 AM
ron_van_sommeren
Topicstarter's last registered activity was has first and only post here.
GunnyJeeves
09-17-2013 07:05 PM
TAUMULLER
Warbird Electrics
15
06-27-2012 11:37 PM
Quick Reply: Which motor to upgrade to on Durafly/Banana Hobby T28?
Page generated in 0.09438 seconds with 10 queries
