KW club
Old 08-21-2008, 09:54 PM
Liquidity
Combat Vet
Liquidity's Avatar
Originally Posted by Mike Parsons View Post
Absolutely. If one side X2 equals >999.99KW, your in
Here you go Mike. This is the Eagle tree from one of the motors.
x2 it will be 1650W I will get you a pic later if you want.
Name:	Deuces Wild Runup.jpg
Liquidity is offline
Old 08-22-2008, 12:21 AM
Mike Parsons
Penguins still can't fly
Mike Parsons's Avatar
Sweet
Mike Parsons is offline
Old 08-25-2008, 01:32 AM
powerlines
I AM NO SHOES!!!
powerlines's Avatar
Default My 1000 watt post.. LATER Thanks Firemanbill
Me and Manta1 have the same exact set-up.. I know cause I built them both.. His was pulling like 1146 last time we checked it.. That should qualify both of us.. If not we can get pics of his later..
By the way.. Have I said this is the best flying plane I have ever had my hands on... AWESOME..
55' Katana from 3D Hobby shop... Thanks 2 Ben at 3dhobbyshop.com.!!!
Motrolfly 3625-800 Rewound by Micro Dan at gobrushless.com Thanks again DUDE!!
Castle 80 ESC
Xoar 15x8E
Xcite 4000Mah 4S battzz.
LATER
ID:	76382   Click image for larger version
powerlines is offline
Old 08-25-2008, 01:33 AM
powerlines
I AM NO SHOES!!!
powerlines's Avatar
Sorry for the bad pics.. My wifes friend has our good camera.. This was my sons camera..
LATER
Old 08-25-2008, 02:22 AM
Manta1
No Shoes is MY FRen
Manta1's Avatar
absolutly..except... WE built them both..ok he built his and most of mine .lol
i got the same guts except im running a 90a scorpion esc. HOT HOT HOT planes man..id be honored to put one of your stickers on my plane
Manta1 is offline
Old 08-26-2008, 04:59 AM
Tram
Purveyor of EPP goodness.
Tram's Avatar
I guess I aught to join the club here..
Here's my Eagle Tree of my UCD..
Jeff
www.CommonSenseRC.com
Tram is offline
Old 09-08-2008, 08:42 PM
Manta1
No Shoes is MY FRen
Manta1's Avatar
ok i guess ill have to get a pic in here of mine for a kw sign
Manta1 is offline
Old 09-14-2008, 04:48 AM
BoysToys
BoysToys's Avatar
Default 2,000 Watt Club!!
New batteries and a new member of the 2,000 watt club. I strapped on a new Zippy-R 6s 4800 pack on my T-Rex 600 and set a new max watt record, for me of 2132 watts.
My setup is a Steve Neu 1515/2.5D/F/H 1700kv motor, Castle Creations Phoenix HV85 esc, 600mm VBlades, 11T pinion. I topped out at 2132w, high amp draw of 105A, 20.16v.
Name:	2000 watt T-Rex 600 amps volts.jpg
ID:	78047   Click image for larger version
Name:	2000 watt T-Rex 600.jpg
ID:	78048   Click image for larger version
Name:	2000 watt T-Rex 600 Dash Board.jpg
BoysToys is offline
Old 09-15-2008, 08:38 PM
Mike Parsons
Good job! I have you down for a 2kw as well as the 1kw.
Good news! I just got confirmation my decal inventory will be here this week. So I should be able to catch up and send those I owe a decal out by end of the week..
.....I know Bill..I know
Old 09-15-2008, 09:13 PM
LOL... Ok Mike!
Old 09-22-2008, 02:16 AM
Edge5foamy
3D or DIE!
Edge5foamy's Avatar
Default QQ Yak 54 69''
I have not had a chance to to run it on a wattmeter, but others are getting 2,000w on 6s - http://www.rcgroups.com/forums/showp...5&postcount=62 - mine is on 8s so mine has got to be over 2,000watts.
Setup...
Scorpion 4025-16
CC Phoenix HV 85A
2x 4s 4350mah
Berg 7P
Hitec HS-5625MGs all around
CC BEC 2s 2150mah(Rx pack)
APC-E 17x8
Pics - http://teamflyingcircus.com/forum/at...7&d=1208352276 - http://teamflyingcircus.com/forum/at...6&d=1208352276 - http://teamflyingcircus.com/forum/at...5&d=1208352276
Edge5foamy is offline
Old 09-22-2008, 02:14 PM
EDFrules
GravesRC enabler d:)
EDFrules's Avatar
Almost breaking the 4kw club but 3kw is fine too! Here's my 3DHS 87" Extra 300 SHP with the initial A123 setup. Switching back to lipos if that tells you anything...Here's the powerplant setup:
Hacker A60-18L/Hacker Spin 99/14s2p A123's 24 x 12 APC e. Plus 2 x A123's for the Rx pack. AUW around 18lbs.
1st flight numbers from Spin Box:
Here's some numbers off the Spin Box for flight 1 with the A123's. Guessing weight around high 17 to 18+lbs :
Max Current: 78.3A
39.06V 6:41 duration
Min. Current: 44.6A
40.74V 7:47 duration
Max Voltage: 47.89V
Min Votage: 38.92V
Actual Voltage: 48.83V
Off Voltage: 44.31
Motor Run Time: 6:31
Flight #2:
Max Current: 81.7 amps
38.35v 7:46min.
Min. Current: 57.2amps
40.23v 3:54min.
Max Voltage: 52,85v
Min. Voltage: 36.91v
Actual: 53.16v
Off Voltage : 43.07v
Motor Run Time: 7:50min.
Power on time: 9:03
Had issues with A123's and am switching back to lipos. I'll try and update with some more Spin Box numbers with lipos. Looks like I might have broken 4kw with the last flight using a 25 x 12.5 apc-e. But mid 3500-3700watts is probably a reasonable estimate. Lots of fun and what an airframe! This is arguably one of the best 50cc sized airframes on the market today. I made some SFG's for my beta test version but the production versions all have them stock. Even better KE and rolling maneuvers with it. I'll also be trying out a Scorpion 5455 when they come out too. Should have a Neu 1521 sometime this year to test out too. Probably going to save that one for Bipe-XXL though Let me know what I've got to do to grab a 3KW sticker!
Name:	Extra 300 SHP 87 inch A123 powered !.JPG
ID:	78831   Click image for larger version
Name:	Extra 300 SHP 15.JPG
ID:	78832   Click image for larger version
Name:	Extra 300 SHP 87 inch maiden .JPG
ID:	78833   Click image for larger version
Name:	Extra 300 SHP 87 inch KE pass.JPG
ID:	78834   Click image for larger version
Name:	Ugly Mug, Pretty Mug and the Extra.jpg
Name:	Extra 300 SHP SFG 5.JPG
EDFrules is offline
Old 09-22-2008, 04:04 PM
  #63
Mike Parsons
I just need a photo of the wattmeter results and or setup and Ill get a decal out to you.
[quote=Edge5foamy;479019]I have not had a chance to to run it on a wattmeter, but others are getting 2,000w on 6s - http://www.rcgroups.com/forums/showp...5&postcount=62 - mine is on 8s so mine has got to be over 2,000watts.
Setup...
Scorpion 4025-16
CC Phoenix HV 85A
2x 4s 4350mah
Berg 7P
APC-E 17x8
Old 09-22-2008, 04:06 PM
  #64
Mike Parsons
Thats awesome! I am glad to see some real world numbers as this is my exact setup in my new baby. 88.5" EFRC Extra. Send me your address and I will get a decal out to you.
Old 09-22-2008, 04:07 PM
  #65
Mike Parsons
I mailed out 6 envelopes with decals in them this morning. So expect to see them in your mailbox this week. That should be everyone that I owe a decal and caught up to this point.
Old 09-22-2008, 04:15 PM
  #66
Liquidity
Combat Vet
Liquidity's Avatar
Setup...
Scorpion 4025-16
CC Phoenix HV 85A
2x 4s 4350mah
Berg 7P
APC-E 17x8
Bring to the EFlyin at Hodges. We can put my Eagletree in it
Old 09-22-2008, 04:20 PM
  #67
EDFrules
EDFrules's Avatar
Thanks Mike! Sent you my address. Glad you're enjoying your EF Extra. Trying out Xoar 24 x 12-looks like you've got one on your bird too. Gotta love Giant Scale Electrics!!!
EDFrules is offline
Old 09-23-2008, 12:05 AM
  #68
Edge5foamy
3D or DIE!
Edge5foamy's Avatar
I was going to, but I am pushing it just bringing the planes I am going to "try" to bring.
We'll have to do it some other time.
Old 09-24-2008, 04:43 AM
  #69
gzsfrk
gzsfrk's Avatar
Hey Mike! I've got another one for ya'.
I'm really excited to be posting this--even moreso than I was when I posted my Screamin' Delta Demon to the 100+MPH thread.
This is my submission for the 1KW badge:
Plane: World Models Rambler - 30 (bought used without a power setup)
Motor: Turnigy 50-55 600
ESC: Flying 70A Brushless ESC
Prop: JXF 12x8 Poly Composite
Battery: 4 x ABF ~20C 2200mah 3S lipos wired in a 6S2P configuration (4400mah 6S)
I hooked the plane up to my Watts Up! meter, braced it, set it to full throttle, and I got a max watt reading of 1336W, with a peak amp reading of 60.95A. Pictures of the meter readings are below:
ID:	79050 Click image for larger version
Below is a picture of the plane just before the maiden:
And of course the obligatory embarassing photo the wife took of the plane nosed in because I forgot to keep up elevator applied while taxiing across the rough soccer turf after landing.
Here's a fixed angle video I took of the maiden:
[media]http://www.vimeo.com/1791692[/media]
Doppler analysis showed my fastest flyby at between 103 and 106mph. And you gotta love the sound it makes flying over--almost like a real plane.
Also, for reference, here's a thread I started covering the experience of my maiden flight with the plane.
Let me know if I need to provide some additional information or pics, Mike.
Man, I'm so giddy about this. Ya'll here on WF have sure turned me into SUCH a plane nerd.
Thanks for that.
gzsfrk is offline
Old 09-24-2008, 01:16 PM
  #70
Mike Parsons
Sweet! Congratulations! And welcome to the club. I will get a decal out to you today. Just PM me your snail mail address
Old 09-25-2008, 03:31 AM
  #71
Mike, I FINALLY got my stickers today! Thanks Buddy!
Looks real good on the nose too!
Old 09-25-2008, 01:38 PM
  #72
Mike Parsons
Awesome! Thanks for the photo Bill
Old 09-25-2008, 03:44 PM
  #73
Manta1
No Shoes is MY FRen
Manta1's Avatar
thankyou for my kw sticker!i received it yesterday...how do i put a kw sign under my nick in here?
Manta1 is offline
Old 09-25-2008, 03:45 PM
  #74
Manta1
No Shoes is MY FRen
Manta1's Avatar
ill have 2 more planes going over a kw after this weekend i imagine.1 i know,the ohter may be close.lol
Manta1 is offline
Old 09-25-2008, 04:29 PM
  #75
Mike Parsons
Ill do that for you. I should have done it earlier, but missed you somehow? I blame it on old age!
Quick Reply: KW club
Page generated in 0.15021 seconds with 25 queries
