Building my own 70mm twin Jet - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 06-24-2011, 05:50 PM
lvjet
Default Building my own 70mm twin Jet
After buying a Projet twin F-4 and haveing it smash threw some guys fence because of the lack of elevator it had, and buying the HET single F-18 and haveing that one blowup on me in mid air I've decided to design and build my own twin 70mm EDF. I've tried to modify the F-18 so the elevons had less slop. It still flys good but I like my planes to have a landing gear. So this project will probably take me a month or so. Ill post pics of its progression.
lvjet is offline
Old 06-24-2011, 08:14 PM
lvjet
Heres a look at what i'm up to so far.
ID:	150052   Click image for larger version
ID:	150053   Click image for larger version
Name:	fan drawing.JPG
ID:	150054   Click image for larger version
Name:	tail cones.JPG
ID:	150055   Click image for larger version
lvjet is offline
Old 06-27-2011, 04:16 AM
lvjet
Heres some more construction pics
ID:	150156   Click image for larger version
Name:	FRONT FORMER.JPG
ID:	150157   Click image for larger version
ID:	150158   Click image for larger version
ID:	150159   Click image for larger version
lvjet is offline
Old 06-27-2011, 05:22 AM
Hi, your jet looks nice, but i see one problem, the edf housing is together and makes for a large frontal area and a lot of drag, also the slant on the front of the motor housing is going to act like a flap, and cause frontal lift, and you might have a squirrly plane, the jet housing on a Mig 29 fulcrum might be a better way to go, Just my 2 cents worth, take care and have fun, Chellie
Old 06-27-2011, 02:47 PM
lvjet
Hi Chellie ,
I was considering the idea of a frontal pc which will streamline the ducts. What do you think about the thought of leaveing the center section open and placeing the ESC's in there for cooling?? Thanks Chellie for your advise. Still think your the coolest Girl out there.
lvjet is offline
Old 06-27-2011, 10:52 PM
Hi Chellie ,
Thank you for the complement leaving the center open will cause a lot of drag, because of the wood ribs, if you still want to use your wood frames, tappering the frontal air scoop and ducting/streamlining the air into the EDFs may help a lot, and get rid of a lot of drag, making 2 edf motor housings, like the mig 29 and with nothing between the 2 edfs may work much better, just my 2 cents worth Take care and have fun, Chellie
Old 06-27-2011, 11:26 PM
lvjet
You certainly know alot about the hobby. Thanks for your replys. George
lvjet is offline
Old 06-28-2011, 04:01 AM
Hi George I have been in this wonderful Hobby for over 40 years, yes i know i look 29 but i am a little older than that LOL, and I am Just Plane Crazy Take care and have fun, Chellie
Old 06-28-2011, 05:02 AM
tampaflyer
to the skies of tampa
tampaflyer's Avatar
good luck.. looking good
tampaflyer is offline
Old 07-03-2011, 08:18 PM
lvjet
Getting a little farther along here. Drawings take the most time. Enjoy.
ID:	150387   Click image for larger version
ID:	150388   Click image for larger version
Name:	inner 3-d ribs.JPG
ID:	150389   Click image for larger version
ID:	150390   Click image for larger version
Name:	spar layout.JPG
ID:	150393   Click image for larger version
Name:	top duct work.JPG
lvjet is offline
Old 07-10-2011, 01:55 AM
lvjet
This is starting to get exciting. About 1/2 done. I have to build in the rudder and the upper deck. Canards, hingeing , radio work. Im figuring it will be close by the end of August. Maybe sooner. Its funtions will be , ailerons, elevator with the canard added and, rudder control.
Name:	bottom sk 2.JPG
ID:	150593   Click image for larger version
Name:	bottom skin 1.JPG
ID:	150594   Click image for larger version
ID:	150595   Click image for larger version
ID:	150596   Click image for larger version
Name:	partial fitting1.JPG
lvjet is offline
Old 07-10-2011, 11:35 AM
Thats looking very very nice and strong, Keep up the great work, Chellie
Old 07-10-2011, 06:29 PM
lvjet
Thanks alot Chellie. It has'nt been easy. Im watching out for trapping myself in a corner with this. Its easy if you continue to build without thought to what the finish product is going to turn out like. I still have to break up the upper deck solid into formers. Alot of drawing, but I love to draw so it does'nt bother me. I wish I could do something about that frontal area, but I do not want to cut up the Fusalage. With the 50 degree angle in the front it tends to pull the nose down. Interesting huh. It must have something to do with the velocity difference between the top of the duct and the bottom. With the landing gear installed it not as noticeable. Neat stuff. Love it!
lvjet is offline
Old 07-26-2011, 03:41 PM
lvjet
Here was another major assembly finished last weekend. 62 drawings so far and, 120 CNC programs. Its been alot of work so far. It better fly!
ID:	151222   Click image for larger version
ID:	151223   Click image for larger version
ID:	151224   Click image for larger version
lvjet is offline
Old 08-03-2011, 07:13 PM
road king 97
old hat
road king 97's Avatar
Very nice build ,looks great . joe
road king 97 is offline
Old 08-03-2011, 07:19 PM
HeliScRapYard
Foam Junkie
HeliScRapYard's Avatar
waiting for the videos, very nice
HeliScRapYard is offline
Old 08-05-2011, 03:16 AM
lvjet
More pics
ID:	151554   Click image for larger version
ID:	151556   Click image for larger version
ID:	151557   Click image for larger version
ID:	151558   Click image for larger version
ID:	151560   Click image for larger version
ID:	151561   Click image for larger version
ID:	151562   Click image for larger version
lvjet is offline
Old 08-05-2011, 04:06 AM
road king 97
old hat
Do you have your own lazer or do you have some one cutting things out for you ? I hope there will be plans for sale ,i was thinking about building a vampire but this looks very nice . joe
Old 08-05-2011, 05:22 AM
lvjet
I cut the pcs myself with a cnc mill that I own. Any question s feel free to ask.
lvjet is offline
Old 08-05-2011, 06:37 AM
road king 97
old hat
I have been cutting all my own parts out for 30+ years by hand . I have to where glasses for close up stuff now but not the end of the world. When i start building it i can tell the days when i lost my glasses while i was cutting parts out,kinda rough. lol You do nice work friend ! I can barely post with a computer so plans i draw or change are done by hand . It takes me a little longer but this aint a race and i am in no hurry any more. joe
Old 08-05-2011, 08:24 PM
lvjet
Hi Joe, Sounds like your about my age. Glasses to see with. If I had enough responces I was thinking about sending the project to a cnc lazor shop to cut the pcs out. Since I have the drawings it might be do-able. As fars as plans I would have to go to a drafting place to have them printed to scale. I think after its maiden flight I would be able to help you out. Lets see how she flys first. Im still estimating it will be ready to fly by the end of this month. Ill take a video of that. Thanks for your nice compliments. George.
lvjet is offline
Old 08-05-2011, 10:06 PM
road king 97
old hat
Iam almost 55 my eyes started to go south at 40. Iam lucky i have built enough planes to crash cause i cant see them. I have no jets in my fleet but was getting a little nutty a month ago and thought about putting a fan in peter rakes vampire prop pusher jet. I was looking for a balsa jet that had no foam and not to much figerglassing to do to it. I normaly go for 40,s or 50.s birds and have been on a seaplane kick for a while but i have found a giant paved parking lot( about 2 blocks by 2 blocks) at a high school thats close to my house . We have a couple jet jockys at my club field but they like flying at 120 plus through the flight pattern of others so i was looking for a smaller e jet . Looking foward to the rest of your build she is looking good. joe
Old 08-05-2011, 11:38 PM
lvjet
I am 50 years old and the same story on the eyes. If all goes to plan this Jet should be docile and aerobatic. It has all flying surfaces. The wing is symetrical for a neutral effect. It should roll, fly inverted an so on. Covering I have'nt done in 10 years and its beed challenging to say the least. The upper deck was the worst . Probably should have painted it , but was afraid to add the extra weight. Im shooting for 7 to 9 Lbs max. With the wing area I have incorporated into the model, it should have a real nice glide ratio. We will see. Talk to you later. George
lvjet is offline
Old 08-06-2011, 12:11 AM
road king 97
old hat
Hey george, i just caught this on another site ,i have used water based hardwood floor clear and cloth but this guy used deft to cover and then paint his birds with little extra weight. http://www.rcuniverse.com/forum/m_10...m.htm#10655561 joe
Old 08-06-2011, 03:10 AM
lvjet
Hey thats nice. Im going to use that in future projects. Joe you got to see this;
http://www.flixxy.com/airplane-flies-like-a-bird.htm
lvjet is offline
Quick Reply: Building my own 70mm twin Jet
Page generated in 0.11860 seconds with 49 queries
