B-47 8.77th (1:8.7669) Scale, Boeing Stratojet Component Assembly
Old 01-15-2019, 01:03 AM
  #276
She is a tolerant woman to let you play it so many times.
Old 01-15-2019, 03:28 AM
  #277
Flite-Metal
"Look Of The Real Thing"
Flite-Metal's Avatar
Default Boxed Until Next Thanksgiving
Well, its boxed and going to the storage unit for nine months... :^( I had the Dickens
getting it back in the box...as thought it didn't want to go... Like they say...keep'em
wanting more...Looking forward to listening maybe four times next year...
Flite-Metal is offline
Old 01-31-2019, 01:48 PM
  #278
Flite-Metal
Default CG & Wing Pre-load Affirmation
Back on track...
Because documentation is so scarce for the B-47 due to records being destroyed by being burnt
at all B-47 contractor locations for manufacture, servicing, and maintenance as a result of security
during the high point of the Cold War...it has taken nearly 10 years to find technical resources for
this project. Something of this magnitude can not be achieved with supposition. There are too many
loose ends.
Early on I referred to this as herding cats.
This morning I discovered resources in support of the CG location calculated. Using online calculators
has always been something of an accuracy issue for a normal aka regular r/c model...the value of the
B-47 collaborative resources leaves me just a wee paranoid. I have questioned everyone who has had
the fortunate task where their CG was located as well as reviewing the engineered drawings obtained.
This video exemplifies the severe consequences of both wing pre-load and CG. The easy answer for
the CG is "seen" in the wind tunnel tethered B-47. Consequence of unloaded or under-loaded wings
is graphically illustrated as well.
Click
to watch archival footage of Boeing wind tunnel testing of the B-47.
Old 03-04-2019, 08:51 PM
  #279
Flite-Metal
Default B-47 Canopy & Cockpit Coming Right Along
The Boeing B-47 Stratojet's canopy is the same as the two place T-33. With one exception... The B-47 canopy has an extension beyond the third overhead frame member. See red arrow.
Unlike the B-47 the T-33 has its rear section split with the hinge mechanics within it.
While the Bob Violett T-33's canopy is the exact size for my B-47...I need to add this extension to it to match the B-47's. The choice I made was to purchase an aerobatic canopy and trim off rear portion of its canopy to add onto the rear of the T-33 canopy.
While this is pretty straight forward...I need to glue the two together beneath B-47'S overhead rear cross member. This sounds pretty simple doesn't it . However, the B-47 canopy moves to the rear about one inch as its front rises two inches for ventilation.
The motion to achieve this is from an attachment to the canopy rear...attached to the add on section.... This is going to have to endure a fair amount of stress/vibration when it is down and latched as well during its rearward motion.
Can someone make a recommendation which adhesive will adhere to the appended clear canopy joint and overhead frame member and not suffer the consequence of vibration? Remember it is pulling the entire canopy over a lift point located 1/3 down the length of the 24" long canopy.
Old 03-04-2019, 10:08 PM
  #280
Would a thin line of Goop work?
Old 03-04-2019, 11:32 PM
  #281
Flite-Metal
Default Altering B-47~BVM T-33 Canopies
Don,
Therein lies the issue. The simple fix would be Goop if it were not for the fact both the front and rear
canopy "ends" rise as the canopy is moved rearward. I am afraid Goop will not be strong enough to
keep the front and rear adhered as a unit set. Hope someone can advise what to use.
Old 03-24-2019, 08:19 PM
  #282
Flite-Metal
Getting there...doing cockpit prototype this week-end-week...
Flite-Metal
276
03-22-2019 12:49 PM
Flite-Metal
544
10-12-2018 01:18 PM
Quick Reply: B-47 8.77th (1:8.7669) Scale, Boeing Stratojet Component Assembly
Page generated in 0.07820 seconds with 13 queries
