iCharger storage Voltage - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 11-27-2016, 01:22 PM
Merlotmaker
Default iCharger storage Voltage
I need to know how to set the LIPO storage V very accurately.
Currently LIPO storage cycle is set to 3.85V per cell but I would prefer this V to be 3.80V.
I cannot find a parameter or setting on the iCharger 3010B to set this Voltage.
Can you please assist?
Thnaks
Merlotmaker is offline
Old 11-27-2016, 04:53 PM
5/100ths of a volt is not much to concern yourself with.
Old 11-27-2016, 10:56 PM
Seems that most chargers are set to 3.85
Many cannot be changed from that as well.
For user settable discharge and good rates - the 3in1 MyRCMart discharger at about $14 is a great bit of kit. Then you have charger left to do its primary job, while the 3in1 at 150W discharge gets your pack to storage balanced and automatically.
Old 11-28-2016, 12:33 PM
Looking at the manual I'm not sure you can adjust it. I used to own a 3010b but never tried adjusting the storage voltage.
I'm wondering why you would want to. Anything in the 3.7-3.9V range is fine, it's not an exact science.
I've now got the 4010 Duo and that does have the option to adjust storage target voltage but I've not had reason to do so.
Old 11-28-2016, 03:41 PM
I have the Icharger 208B and never use it for discharging. Bought the HobbyMart 3 and 1 on Nigel's suggestion and have not looked back.
When I'm at the field, I generally know about what to expect the v/cell to be on most of my planes based on how I've set the timer. I do check voltage after a flight. and if it's in the general happy range, I'm good. Sometimes, if I need go lower, I'll just run the motor a little longer.
For lipos that I've pre-charged to the max 4.2V/cell but did not use for one reason or another, that's when I use the HobbyMart discharger.
Old 11-29-2016, 12:17 AM
For discharge I run the batteries down in on a larger 6S system. With a wattmeter and balance checker I can burn them down pretty quick. I prefer to discharge lower and then use the storage charge setting to bring them up to 3.85vpc.
I can't see generating all that heat discharging in a $200 charger as being a good thing.
Old 11-29-2016, 10:57 PM
dereckbc
You can change it to anything you want. Question is why?
Storage voltage is not critical as long as it is not fully charged or discharged. Anywhere greater than 20% or less than 80% is fine. 3.85 volts is the upper limit and chosen by manufactures because it yields the longest storage time of 1 year.
ichargers are accurate, but using voltage to determine State if Charge cannot be done with any accuracy. Voltage can only be used on a well rested battery. Even then voltage is only a Ball Park figure +/-20%. So worrying about the exact voltage you store them is futile. Only two voltages you need to be worried about is 3.0 and 4.2 volts.
dereckbc is offline
Suprawill1
Electric Ducted Fan Jets
16
07-13-2016 08:20 PM
Positive Charge
71
12-18-2013 11:08 PM
aeroknot
06-14-2011 03:12 PM
Quick Reply: iCharger storage Voltage
Page generated in 0.09384 seconds with 13 queries
