Powerlab 6 and Li-ion Charging
Old 12-11-2015, 02:52 AM
Rich B
Default Powerlab 6 and Li-ion Charging
if someone could assist me in charging two Fromeco 2600 mah 7.4 volt Li-ion batteries that are installed in a 50cc plane. These batteries are setup to be charged through side exiting charge ports (servo style plugs) i would greatly appreciate it. A step by step method is what I am looking for. i am new to charging Li-ion's and the Powerlab 6 states that it charges them. I am at a loss of how to go about it with this planes setup and this charger. Thanks in advance.
Rich
Rich B is offline
Old 12-11-2015, 02:46 PM
Flubber
Flubber's Avatar
You will need to add a preset from the library in the charger for non balance li-ion. It is petty easy just search "powerlab 6 library" for videos on how to do it. You will use a charge connector with a servo plug on the end. Set the charger for 2 cells.
Welcome to watt flyer
Flubber is offline
Page generated in 0.09379 seconds with 11 queries
