Technical Note - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Technical Note
Old 09-09-2014, 10:02 PM
Howard Matos
Production Supervisor
Howard Matos's Avatar
Default Technical Note
Recommendation from our Engineering Department Regarding:
Product: E-Fuel 1200W/50A Power Supply
Model No: SK-200015
When powering any Revolectrix Cellpro Charger or Battery Workstation using the E-Fuel 1200W/50A power supply:
1) First connect the Power Supply to AC power BEFORE connecting the charger to the power supply
2) Set the voltage on the Power Supply so it is within the operating range of the Cellpro Charger or Battery Workstation you will be powering
3) Wait at least 15 seconds
4) Then connect the Cellpro Charger or Battery Workstation to the Power Supply
5) Conversely, disconnect the Cellpro Charger or Battery Workstation from the Power Supply BEFORE disconnecting the Power Supply from AC power
We appreciate your business!
Howard Matos is offline
47
10-25-2013 02:51 AM
TM4197
Warbird Electrics
04-21-2012 10:35 PM
Quick Reply: Technical Note
Page generated in 0.05168 seconds with 13 queries
