HoneyBee CP2 on FMS Sim
Just bought first heli and downloaded FMS. With 6 channel transmitter (Right Rudder) attached by USB lead to my computer, the transmitter controls are all mixed up on sim. Throttle in place of rudder, ailerons in place of throttle etc etc. have tried to adjust this on sim adjustment but no success.
Can anyone help
Can anyone help
Can anyone help
Can anyone help
1. What brand USB interface are you using
2. Is there a control panel for setting channel selections and adjusting throws?
Clint
I'm using a USB two part lead from HongKong named "Mystery" plugged into the Trainer jack of the transmitter. Seems like it's aptly named. I have used the control panel on the FSM drop down menu, selected Joystick, calibrated the controls as recommended. No effect. Have even tried changing the channel numbers to correspond with the actual ones but still no success. Which control panel are you referring to?
Please post pic of FMS Joystick config.
Q - Have you been able to get transmitter to work with FMS planes?
Clint
By the way,my transmitter/controller is Esky 406. My system works with planes and helis but the functions are mixed up in all cases. I just cannot think of another solution. Maybe it's the lead. It seems peculiar to have a four pin connection from the transmitter then use a jack plug connector before the USB connection to my PC. Thanks for trying anyway. I guess I'll just have to get a full sim kitto get some practic.
All the best, Don
All the best, Don
All the best, Don
All the best, Don
2. If you can calibrate using FMS analog joystick dialog and can see each one of the controls respond on the screen, you should be able to get it to work.
Note: I use FMS with 4 channel ESKY 72 MHZ radio that has analog signal output to connect to sound card mic input. Works like a champ in FMS
Clint
