Thermals in FMS
Old 06-03-2008, 02:25 AM
FlyWheel
Ochroma Pyramidale Tekton
FlyWheel's Avatar
Default Thermals in FMS
Quick question, when you add thermals in the FMS Sim, is it a general thermal that is spread over the entire flying field, or is it/are they isolated phenomena that you have to find?
FlyWheel is offline
Old 06-09-2008, 01:23 AM
FlyWheel
FlyWheel's Avatar
Nobody knows?
FlyWheel is offline
Old 06-10-2008, 09:35 PM
DelawareDon
Isolated....but not at all difficult to find.
DelawareDon is offline
Old 06-11-2008, 01:42 AM
FlyWheel
FlyWheel's Avatar
Thanks. Since gracefully soaring birds are scarce in the FMS universe, I suppose I just wander around until the plane starts rising? Or do I just fly above those areas likely to cause them? I.E. dark patches of ground.
FlyWheel is offline
Old 06-11-2008, 02:48 AM
DelawareDon
I've discovered that they are most frequently found where air is likely to move up the side of mountains and create an updraft. But just enjoy lazily floating around the sky, and I'm sure that you will find that you're gaining altitude. In fact, I've frequently "skyed out"(gone out of sight above the clouds), and have had to put the plane into a controlled spin (move the right toggle to about the 4:30 position and hold it there) to get it back into view. Sometimes it's pretty difficult to get it back down to an altitude where you can land.
Old 06-11-2008, 03:11 AM
FlyWheel
FlyWheel's Avatar
That answers another question I had; would adding wind in a mountainous landscape create updrafts for sloping.
Thank, guys.
FlyWheel is offline
Old 01-13-2009, 05:42 PM
MaxAdventure
AMA 198798
MaxAdventure's Avatar
Default Other sims?
is FMS the only sim with thermals? Are there attributes that can be altered to create them in any other software? I need to get an interface and install FMS, i'm using RF 3.5 right now. I can only find slope lift, but there's no boundry layer for DSing, which is irritating. Or I just plane don't understand how to set up the environment.
MaxAdventure is offline
Old 01-22-2009, 06:43 PM
cbatters
cbatters's Avatar
Any suggestions on backgrounds with thermals or backgrounds that allow slope soaring?
Thx,
Clint
cbatters is offline
Voyager2lcats
Crash and Safety Forum
13
11-13-2009 04:51 AM
bigsi40
Flight Simulators
04-25-2008 03:08 AM
Epowerreg
11-14-2007 08:14 PM
CygnusX1
Video Parking lot
10-22-2007 04:59 AM
05-16-2007 04:32 AM
Quick Reply: Thermals in FMS
Page generated in 0.09736 seconds with 13 queries
