Flyzone Micro Albatros - Page 13 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 08-27-2014, 05:21 AM
  #301
Griff Murphey
I am currently flying the SE-5 and DR-1 and have "gone through" two other SE-5s and a Nieuport 17. All came with down and right thrust. I assume that yes you would need that on the Albatros.
I have put similar down and right thrust on my micro stick and tissues with Flyzone micro guts and it seems necessary.
Griff Murphey is offline
Old 08-28-2014, 06:57 AM
  #302
Virgil Kee
Default Thrust Angles - UM Albatros
As you've already read, down and right thrust are a must on any ultra micro, (or any other model for that matter)!
You'll need to open the fuselage, of course, to access the motor/gear drive. When you are ready to close back up, you'll have access to paint the round parts of the fuselage just behind the spinner. I've had four of this UM and this is your chance to correct the poor paint job in this area.
Go for about 2 degrees or less of both down and right thrust. Try to position the motor and gear box so as to center the spinner in the round fuselage opening.
First, try a "dry fit", noting any changes needed in the original mounting location to achieve the best spinner location. Go back in to make any needed adjustments in the seating location. Now you're ready to close up the fuselage again. CAUTION: test all control functions and motor operation BEFORE final closing!
This is a good flying plane. Keep it in operating condition! Don't toss it out just because some repairs are needed.
Good luck, - Virg.
Virgil Kee is offline
7car7
WWI Era
68
08-19-2014 10:36 PM
Catalina
Electric Ducted Fan Jets
10
08-12-2010 01:43 PM
thunder1
WWI Era
07-06-2008 03:17 AM
degreen60
WWI Era
56
03-24-2008 07:54 PM
ray2006
03-18-2008 04:36 PM
Quick Reply: Flyzone Micro Albatros
Page generated in 0.04945 seconds with 12 queries
