a radio to not get - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
a radio to not get
Old 08-03-2011, 03:25 PM
kevinm
Default a radio to not get
well, while juggling systems i thought id put the hitec focus III radio in the old cox sportavia (throttle, rudder, ele, perfect for the sportavia right?) i had upgraded with a fast brushless - bad idea -this radio has the throttle hidden on the back for some goofy reason , {{out of sight out of mind}}, it spun in hard at full throttle seconds after hand launching - angry at myself for knowing better than to try to use the weird radio , but doing it anyway-
my thumbs are kinda sorta trained - i wont put this radio on another plane--
dont know if this is the place for this post im just upset at my tomfoolery
kevinm is offline
Old 08-03-2011, 05:02 PM
There's been a change in the programming of The Matrix...
Old 08-04-2011, 12:00 AM
it really is the dumbest design of a TX to put a slide throttle on the back of the tx.....what were they thinking.i also have one in a storage closet,but the trash can would be better.bought it years ago when i first got into building kits.
i only used it a couple of times and accidentally throttled up enough times to stop using it......,on the brighter side ,I've been using the hitec optic 6 with the spectrum module and an assan 2.4 module flawlessly on all my birds.
Old 08-04-2011, 12:07 AM
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
Wink
Hi Stu
I have one laying around it came with a RTF Firebird Freedom
Quite an awful design to say the least
I used it once and then added it to my collection of vintage TX's
Take care dear friend
Yours Hank
kenchiroalpha is offline
Old 08-04-2011, 12:42 AM
LOL
I've got one of those transmitters! Tried to make it work with a receiver last fall, it was dead. It was just for show and tell for some 2nd-8th graders.
Just looked at it today, its AM, the receiver was FM
Oh well, it will never control another model, everything now is 2.4 Ghz Spektrum systems.
Old 08-04-2011, 12:48 AM
flydiver
flydiver's Avatar
I can see where that could be a problem. OTOH mine works fine on a slope delta > no throttle.
flydiver is offline
Old 08-04-2011, 01:12 AM
dkrhardy
IMHO any kind of slide control is not good. REALLY not good! Did I tell you that I think slide controls are not good?
dkrhardy is offline
Old 08-04-2011, 02:33 AM
Just a note, you have "Slide Controls" where crap can get inside the slide control and cause problems.
And you have "Slide Controls" like that used on this Hitec transmitter where the slide control is actually connected to a standard sealed potentiometer inside the transmitter.
As you indicated, still don't like it.
Old 08-04-2011, 03:36 AM
kenchiroalpha
Wink
Hi
The only slider throttles imho that work well are on some of the UM indoor flyers
In that respect they work well
Heres a few of mine that use that method
Do enjoy
Take care
Yours Hank
Old 08-04-2011, 05:31 AM
lucas2696
NO MORE GLUE??!!!
lucas2696's Avatar
I have one of those that I got with my RTF Easystar years ago, I don't understand what's to gripe about, unless you can't learn to use it very quickly. I still use that radio on this plane, even with the servos that were in the EZ* too.
http://www.srbatteries.com/cutie.htm
lucas2696 is offline
Old 08-04-2011, 05:44 AM
Problem I had was horrible radio interference problems with an Astroflight geared 05 brush type motor on a sailplane model. Never really got rid of the interference until going to 72 Mhz FM radios.
Old 08-04-2011, 05:46 AM
lucas2696
NO MORE GLUE??!!!
lucas2696's Avatar
Even when I had a geared 400 brushed motor on the Cutie, never had any problems, but hey, everyone is different.
Old 08-04-2011, 06:17 AM
Problem is in a sailplane, their is not much room to keep the receiver away from the motor, battery and ESC. The first attempts with this system, the range was only 20% of normal, completely unsafe to fly.
And, the higher powered electric brush type motors really cause problems. Had an Astro 90 brush motor on 38 Nicad cells that had a range of about 15 feet. With the Futaba FM transmitter antenna fully extended. Took a lot electronic fixing to make that thing work.
Old 08-05-2011, 10:31 AM
Cool
I have had two Hitec Focus Radios. The first was an AM radio that came in my Spirit Select 2 Meter glider. The second I got with a used parkflyer. Believe I still have one of them.
They worked flawlessly. I never had a problem with either one.
Third channel in the back was never a problem. Actually very easy to use.
On my electrics, that was the throttle
On my gliders, that was the spoilers.
The Focus was replaced by the Hitec Neon. That also has he throttle on the back. That one has worked fine too.
AEAJR is offline
Old 08-07-2011, 03:27 PM
dkrhardy
OK, some sliders may be the Rolls Royce of sliders, BUT I don't like the way they FEEL and WORK in my hands. Just seems strange.
dkrhardy is offline
Old 08-07-2011, 04:10 PM
kevinm
i just barely got my thumbs trained into an orientation and i shouldnt have messed with success- similarly, i wont need a tx with throttle on the right stick anytime soon lol- dont understand why they hid the throttle , this is to be sure a very good quality radio for a slope flyer , it seems very well built -even the slider feels nice and greasy
kevinm is offline
Old 08-07-2011, 04:35 PM
road king 97
old hat
road king 97's Avatar
I have one also and it took a bit to get use to but i was able to fly wih it . It was not my first choice to grab it when going out the door tho .lol joe
road king 97 is offline
Hose Man
36
10-17-2011 01:19 AM
eseeweb
07-22-2011 12:31 PM
brutusjm
06-13-2011 08:23 AM
wlester
05-10-2011 11:53 AM
gcedillo
01-06-2011 03:18 AM
Quick Reply: a radio to not get
Page generated in 0.12934 seconds with 13 queries
