Spectra vs. Spektrum
Old 06-22-2006, 04:17 AM
Ribcracker
Flight Junkie
Ribcracker's Avatar
Question Spectra vs. Spektrum
I'll be upgrading my radio soon and would like to step into the 21st century. What is the difference between Spectra (Hitec) and Spektrum (Horizon)?
Can I use the Optic 6 w/ spectra module with my old receivers?
Someone told me I couldn't use my old rxs with the DX6. I've got about a dozen FM receivers. I'd hate for them to be useless.
The answer will help me determine which to buy.
Thanks, guys.
Ribcracker is offline
Old 06-22-2006, 04:21 AM
JimClark
JimClark's Avatar
If you want to reuse the recievers you have your problem solved as the only thing you can do is to go spektra.
Jim
JimClark is offline
Old 06-22-2006, 04:27 AM
Twmaster
Registered User
Twmaster's Avatar
The Hitec with Spectra is compatible with all of your FM 72MHz RXs other than PCM units from anybody but Hitec.
The Spectra unit is a module that allows you to select any of the 72MHz airplane channels. (you turn a couple of dials to set the channel).
The Spektrum is a completely different animal that works on a different frequency band (2.4 GHz) and is not at all compatible with your current FM RXs
Twmaster is offline
yup, fm receivers will not work with the Spektrum.
firemanbill is online now
ElectricCow
08-30-2007 05:01 PM
John-NYC
05-25-2007 10:23 PM
lostagain
01-06-2007 12:37 PM
Jim Condor
06-15-2006 10:34 PM
stroland
02-25-2006 06:58 PM
Quick Reply: Spectra vs. Spektrum
Page generated in 0.06487 seconds with 13 queries
