timber x - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
timber x
Old 01-15-2020, 01:00 AM
Ken
Default timber x
Hello I just received my new timber x and would like to know if i use 4s 2200 batts do i need to use steel rod vs carbon in the tail or is that steel rod help to balance the 4s batts ?? Thanks in advance for your help Ken
Ken is offline
Old 01-15-2020, 10:11 PM
If both steel and carbon are supplied I would be amazed if the assembly instructions did not explain why they are there.
I understand the Timber battery space is pretty restricted so a steel rod alternative to carbon would certainly help obtain the desired CofG.
quorneng is offline
Old 01-18-2020, 07:06 PM
Do you know how to balance the model? If so, place the battery pack, or an equivalent weight in the battery compartment. Now try each set of rods and see how the balance looks.
AEAJR is offline
Old 03-01-2020, 02:10 PM
Tom Sawyer
Tom Sawyer's Avatar
I only use the carbon rod in my Timber x for both 3s and 2200 4s as i found the metal rod spoiled normal flying characteristics by making the plane way too tail heavy - although this did give excellent up elevator authority for those STOL landings the X does so well. I find even then i still have to put my 2200 4s as far forward as it will go. I bought this model as it was the ideal plane for smaller fields and has excellent slow fly abilities - in fact it has the greatest flight envelope of any plane i have ever owned.
Incidentally I also have the Turbo Timber (and a UMX Timber) and much prefer the X as the best all round flyer. If i had to choose only one plane it would be the X.
Tom Sawyer is offline
jangodog
Foamies
16
Yesterday 08:14 PM
jangodog
11-12-2019 09:52 PM
jangodog
05-06-2019 05:46 PM
Foamies
08-04-2018 11:11 AM
Deezil
8
12-22-2017 10:21 PM
Quick Reply: timber x
Page generated in 0.05521 seconds with 13 queries
