Need a servo same size as the old JR MN48 mini - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 06-19-2019, 03:47 PM
Default Need a servo same size as the old JR MN48 mini
This servo has been discontinued long ago and I need one this size. it is in between a mini and full size. Was really an odd servo. E-flite used them in a lot of their stuff and I picked up a Diamante a couple months ago that needs them in the wing.
If anyone has 4 they could let go of or any idea of another one this size that would be awesome.
they are
length 1.3" or 33mm
width 0.58" or 14.7mm
Height 1.02" or 25.9mm
So far nothing I have found comes close to this size.
Thanks in advance
Old 06-25-2019, 01:08 PM
Unhappy
So no one has any ideas about servos? That's a bummer
Old 06-25-2019, 04:54 PM
Hobby King / RC Timer / Banggood give dimensions of the servos and I have found them to be accurate.
TBH - rarely do I find servos that fit factory slots and often I end up adding ply plate to match servo. Modern servos have increased power / speed but shrunk in size compared to the old days ... so using a modern servo of similar size is often a lot more powerful etc.
Old 06-25-2019, 07:00 PM
I have considered doing that but the wing of this plane is so thin it needs the shallow servo to fit in the pocket and it is not hidden so adding ply frame it up to fit something else may look less than stellar. the rudder and elevator are not as big of an issue as they have more access room to use different types
I'll stay on the hunt looking for a pair of those dimensions.
Old 06-25-2019, 08:05 PM
What about the ultra thin servos designed for thin wings ?
Old 06-25-2019, 08:35 PM
So far the only ones I can find are full size and too big. This was a thin mini servo. not full size but not micro either. Really an odd size, it's no wonder they quit making them
Old 06-26-2019, 06:57 PM
MustangMan
MustangMan's Avatar
Would this work? https://hobbyking.com/en_us/corona-d...15sec-22g.html
I realize it's a little larger in one dimension, but slightly smaller in the other two, including being thinner. Can you make room?
MustangMan is offline
Old 06-27-2019, 05:02 AM
gyrocptr
https://www.headsuphobby.com/Power-U...vo_p_1894.html
Power Up 12g Metal Gear Servo Specifications:
Operating Voltage: 4.8~6.0V
Operating Speed (4.8V): 0.12sec/60
Operating Speed (6V): 0.10 sec/60
Stall Torque (4.8V): 30.8 oz /in (2.2 kg/cm)Stall Torque (6V): 35.0 oz/in (2.5 kg/cm)
Dimensions: 0.92 x 0.48 x 0.98 inches (23.2 x 12.0 x 24.8 mm)
Weight: 0.38 ounces (10.8 grams)
Connector Wire Length: 6.5 in. (165 mm.)
Universal "S" connector
gyrocptr is offline
Old 06-27-2019, 01:21 PM
That one is too small to fit the opening without adding additional framing. I actually have some of them.
Old 06-27-2019, 03:46 PM
Here's HK selection that gets as close as possible to the eFlites ..
https://hobbyking.com/en_us/radio-se...0%5D=25&is_v=1
Banggood pages :
https://www.banggood.com/Wholesale-R....html?from=nav
Old 08-22-2019, 07:58 AM
BlumKram
Banned
You can check HK selections on hobbyking.com , I remember there were good options to choose from.
BlumKram is offline
Old 08-22-2019, 02:21 PM
thanks all, I did manage to find a couple from a friend.
01-04-2019 08:37 PM
Larry3215
Foamies
2852
02-04-2017 01:11 PM
ServoCity
New Product Announcements
02-18-2014 03:22 PM
dondi
12-10-2011 01:14 PM
Quick Reply: Need a servo same size as the old JR MN48 mini
Page generated in 0.10573 seconds with 9 queries
