Guillows B-17 Flying Fortress Conversion - Page 4 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-22-2010, 04:09 AM
  #76
dumo01
dumo01
dumo01's Avatar
I didn't see those mods either. Easy to miss some of the little details. Oh well.... Did nothing tonight on the 17 will need to get back on it tomorrow but tomorrow is just me and the dogs here in the evening and they are good build help.
dumo01 is offline
Old 01-22-2010, 04:22 AM
  #77
Legacy
Crash Test Dummy
Legacy's Avatar
I was doing some R&D tonight getting ready for my B-17 build and came accross this thread. You might have seen it already but I figured I would post it just in case. Lots of good ideas that might help. Gave me a good heads up on my retracts. It looks like most of the builds didnt get completed but still helpful. Here it is....
http://www.rcgroups.com/forums/showthread.php?t=827861
Legacy is offline
Old 01-22-2010, 02:17 PM
  #78
park
Clear !
park's Avatar
Last summer I searched and searched for Guillows B-17 build threads and you're right only a hand full finished. I wont get a chance to touch my B-17 for a few days, I'll be putting down wood floors in my house this weekend.
Legacy,
If you want please post your progress on this thread, I think it would be great to have multiple builds on one thread.
park is offline
Old 01-26-2010, 05:03 AM
  #79
Legacy
Crash Test Dummy
Legacy's Avatar
Ok so I have been doing some reading and I found that one successful B-17 conversion used GWS brushed EM300 motors, GWS 5X3 3 blade props, a 7.4v 25c 3700mah lipo, 30 amp esc, and a 3 amp bec. I havent done to many scratch power systems. Is there a brushed motor that is equal but can handle the 11.1v lipos of today? Have you guys decided on your power systems yet? I would like to go with brushless for weight reasons but that would require 4 escs...pricey, and I havent seen a proven b-17 with a brushless set up. Seems it would make sense to go with a proven brushed setup. Im just not much of a motor tech know all. Any ideas?
Legacy is offline
Old 01-26-2010, 01:45 PM
  #80
park
Clear !
park's Avatar
I'm not 100% sure yet, but leaning toward the Heads Up RC 2712-17 brushless motors ($12 each) with four Power Up 10A ESC's ($17 each), a Thunder Power 2S 13C 1320 MAH Batt (I have) and AR500 RX (I have). Not sure about the props.
This is when my build REEAALLLYYY slows down. I bought the kit last summer then in September I joined the %10 club (part time employement) so moneys tight.
park is offline
Old 01-28-2010, 03:08 AM
  #81
dumo01
dumo01
dumo01's Avatar
Working on coverings, have the tail feathers and wings done will start the Fuse in the next day or so and hope to maybe be done with that by the end of the weekend. Will post some pics if I get far enough along. Decided to just use the plastic cowl etc. Decided I just could not do a good duplication of tha smooth curved surface and have it look as good
dumo01 is offline
Old 01-28-2010, 02:15 PM
  #82
park
Clear !
park's Avatar
Looking forward to seeing it, are you going with silver or OD ?
park is offline
Old 01-29-2010, 02:10 AM
  #83
dumo01
dumo01
dumo01's Avatar
OD for the top of the fuse, wings and horizontal stab and elevator. Silver for the vertical stab and rudder, underside of the horizontal stab and elevator, underside of the wings and belly of the fuse. OD for the cowls and nacelles and will coat the whole thing with Testors Dullcoat. Was planning black props, but could only find the props in silver. May paint them as they are more of a light gray not really a silver, but will see how they look.
dumo01 is offline
Old 01-29-2010, 04:29 AM
  #84
park
Clear !
park's Avatar
This is what I'm going to try, the 447th. Not sure if I'm going to have yellow cowls.
park is offline
Old 01-29-2010, 10:59 AM
  #85
dumo01
dumo01
dumo01's Avatar
That will look great
dumo01 is offline
Old 01-29-2010, 02:25 PM
  #86
park
Clear !
park's Avatar
Looking at that picture reminds me of one of the reasons I like building warbirds, they don't have to look clean
park is offline
Old 01-29-2010, 09:30 PM
  #87
dumo01
dumo01
dumo01's Avatar
Yes but it takes way too much effort to get the dirt smudges to look just right
dumo01 is offline
Old 01-30-2010, 12:39 AM
  #88
park
Clear !
park's Avatar
park is offline
Old 02-01-2010, 02:33 PM
  #89
park
Clear !
park's Avatar
I worked on the B17 a little Sunday. I spent most of the time getting my work station back in order after putting down the flooring. I made a modification for the right side cheek gun. Got a couple of questions: See if I made the fuselage door window frame correctly? the directions were not clear. How inportant are the planks at the wing root? I had a very difficult time with the trailing edge ones so I gave up! O, here's a pic of the floor
ID:	119639   Click image for larger version
ID:	119640   Click image for larger version
park is offline
Old 02-01-2010, 09:45 PM
  #90
dumo01
dumo01
dumo01's Avatar
The cheek gun mod looks good. I will probably not try to go back and fix that too much unless I can figure out something to do without taking the covering off. Not sure what that would be. Maybe I can use it for dispalys of " see if you can find the historical inaccuracy" LOL.
The door looks the same as mine if it is wrong we both did it the same for what that is worth.
Not sure what planks you are referring to, can you see them in the pictures in my post #56? If you mean the trailing edges per se, whihc we talked about at some point I think those would be tough to work around. I thought the best way for me was a taable top belt sander to sand off the one side. A mall hand plane would also work I think.
Did not get quite as much done this weekend as I hoped, took a break and crashed some aircraft at the indoor fly Sat night. The SU -26 took a mid air from a larger plane coming up from behind, need a little CF to finish that repair, not too bad. My CX2 took a major hit, not sure what happened. Did a minor repair from a blade strike earlier in the week and all looked OK but when I from the time I lifted off Sat night had no control, crashed on the nose with some body damage and most likely killed the receiver We do this for fun right?
The floor looks great, did it take a lot of trim to get it to fly well?
dumo01 is offline
Old 02-02-2010, 03:11 AM
  #91
park
Clear !
park's Avatar
"Not sure what planks you are referring to, can you see them in the pictures in my post #56?"
No I can't see them. Here's a pic of the front ones installed and one rear one there should be two more at the rear location there called Q planking. It looks like it would be no sweat but I just could not get my fingers or a tool in there to hold it why glueing.
ID:	119683   Click image for larger version
park is offline
Old 02-02-2010, 03:50 AM
  #92
Legacy
Crash Test Dummy
Legacy's Avatar
Can you maybe stick it with a pin and use that to hold it in place and secure it with fast CA. Just a thought, Im no where near that step in my build.
Legacy is offline
Old 02-02-2010, 04:06 AM
  #93
chris123sc
chris123sc's Avatar
How's it going guys? Building a Waco Guillows now and wanting to convert it to brushless, haven't gone through all the posts but wondering if iron on covering will do (low heat)? It seems awefully fragile at this point.
chris123sc is offline
Old 02-02-2010, 04:12 AM
  #94
dumo01
dumo01
dumo01's Avatar
OK now I see what you are talking about. I was able to just wedge them in enough to hold while I got some gap filling CA in a couple spots to hold and then used a little balsa to fill in if needed. I can not see that if would make much difference if they were ther or not except they do give you a little more smooth surface to fasten the coverings in around the wing/ fuselage junction. Don't think they add much if anything at all from a structural standpoint. i wondered after I saw tose and added them if it would have been easier to do earlier in the assembly. Thought maybe imissed a step.
Got the biggest share of the covering done. need to do a little clean up here and there and start on the nacelles and cowls. Was thinking I was moving along well and then started looking and realizing how much I have left to do. Would like to assemble the pieces just to see how it looks, but I do not want to be flipping the whole plane around to work on nacelles. The wing is big enough to be flipping back and forth.
Will try to get some pics up tomorrow.
dumo01 is offline
Old 02-02-2010, 04:17 AM
  #95
dumo01
dumo01
dumo01's Avatar
I am using Ultra-coat on mine, seems to be working fine. The only draw back might be from a weight standpoint. I do not have much experience before this but from what i have read there are other iron on coating that are lighter than the ultra-coat you could look at. I chose the Ultra -coat because it was what I had worked with on a could repairs I had done of a plane i had crashed, the the guys at the LHS recommended it as the easiest to work with in their opinion. Figured for a low level of experience it was a good starting point even if it did add a little to the final AUW
dumo01 is offline
Old 02-02-2010, 04:36 AM
  #96
Legacy
Crash Test Dummy
Legacy's Avatar
I have used a product from World Models called Lightex on a few indoor micro planes where weight was a big issue. Its 5.8grams a square foot. I like it because its strong but its thin so its easy to work with. It also come in a bunch of colors including clear. If you use it go with low heat and warm it up evenly so you dont melt a hole in it. It shrinks really well. I am going to be using it on my B-17 and painting it. You can find it here...
http://www.airborne-models.com/
Legacy is offline
Old 02-02-2010, 03:06 PM
  #97
park
Clear !
park's Avatar
That's a thought. I will try again today, sometimes it helps when you sleep on it.
park is offline
Old 02-02-2010, 03:12 PM
  #98
park
Clear !
park's Avatar
Sounds like the LightTex has Legacy must be very light if used on mini indoor planes. I use Solite I don't know the weight? Good luck with the Waco!
park is offline
Old 02-04-2010, 02:39 AM
  #99
park
Clear !
park's Avatar
Thanks for the tip! I used a pin to hold the plank then glued it in place.
park is offline
Old 02-04-2010, 02:41 AM
  #100
park
Clear !
park's Avatar
I have been cutting and notching the wing ribs.
park is offline
Quick Reply: Guillows B-17 Flying Fortress Conversion
Page generated in 0.10708 seconds with 16 queries
