deans connectors - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
deans connectors
Old 07-26-2008, 03:55 PM
mofosheee
Default deans connectors
I am using wolveriene/ badger switches with 16 AWG wire and deans connectors; male in and and female out.
My batteries and regulators are JR / Futaba type connectors, 22AWG male and female ends.
Is it bad practice to cut these JR/ Futaba ends off and solder Deans connectors in place?
mofosheee is offline
Old 07-26-2008, 06:32 PM
FlyWheel
Ochroma Pyramidale Tekton
FlyWheel's Avatar
Dean's are more likely to be found on the equipment of other flyers at a flying field. That's their main advantage. but you need to solder them on right, or they can be a bear to connect/disconnect.
The best way is to solder each one with it's mate attached (a "Dummy Dean's", attached to nothing and it's wires insulated from each other). This holds the contact's in their proper position so they don't deform from the heat of soldering.
FlyWheel is offline
Old 07-27-2008, 01:02 PM
Hughes500Bob
Full Scale Pilot
Nothing wrong with changing connector ends to suit your preferences. I also change taps, shorten servo leads, and make servo extensions. Sometimes it is more convienient to make adapters. Just remeber to do one wire at a time and assure NO SHORTS.
Hughes500Bob is offline
meddyliol
09-14-2008 05:49 AM
ruffdog
Batteries & Chargers
16
05-14-2008 08:45 PM
olmod
Electronic Builders Workshop
10
03-29-2008 05:23 PM
Huntermd14
01-25-2007 08:21 PM
Positive Charge
11-23-2006 06:17 AM
Quick Reply: deans connectors
Page generated in 0.04847 seconds with 13 queries
