Electronic Builders Workshop Discuss how to build motors, ESC's, chargers, mixers, etc here
R/C Relay circuit
Old 04-23-2017, 01:45 PM
DEEGE
Default R/C Relay circuit
Hi,
I am new to the forum and hope someone can help with this circuit I have found.
I have built and tested it with and it works, up to a point.
The circuit is set up to trigger, with the 100k trimmer when switched from a TX spare channel.
The circuit output works and lights the test LED.
The problem is it will not trigger the relay...
The transistor stage work perfectly when tested separately so I am assuming the comparator is not supplying enough output to trigger the BC 547 transistor.
Can anyone suggest any different transistors or other components that may make it work better?
Regards,
DEEGE
File Type: jpg
DEEGE is offline
RCEM-Joey
06-10-2013 05:53 PM
123rccity
New Product Announcements
04-23-2013 05:57 PM
whitman flyers
Events, Shows and Fun Fly's - Electric Airplanes
01-26-2013 10:40 PM
walter3
ParkFlyers
11
08-28-2012 03:24 PM
Quick Reply: R/C Relay circuit
Page generated in 0.09451 seconds with 15 queries
