Airbrush Suggestions Please.
Old 08-19-2021, 08:56 PM
The Professor
Professional Nerd
The Professor's Avatar
Default Airbrush Suggestions Please.
Not sure if this is the right place to ask this question, but I could do with a bit of advice.....
I need an airbrush that does not cost an arm and/or a leg. I may be prepared to give one or two toes 😜
So having never used an airbrush before, I started cheap. Unfortunately it was too cheap. I spent 20 on an airbrush and a can of gas. That did not work at all.
Then I spent about 45 on a more professional gravity fed airbrush with a little compressor. That was OK, but a little hit and miss. When I used a larger 5 CFM compressor it was ok, but the fan pattern was not consistent. It seems to block very easily and I find that the airflow does not seem to match the trigger position.
So, if you were going to buy a 2 stage airbrush, without spending more than 50..... Which one would you buy?
If possible I would want one with variable fan patterns as well as?
Is this even possible for the price I want to pay.
Any help would be much appreciated
The Professor is offline
Old 08-19-2021, 10:02 PM
I have 4 different and I cannot get the hang of it ... one in fact being an expensive dual action.
But best I ever did was with an old Humbrol single action ... a converted fridge compressor ... back in the 1980's on a Pilot Nieuport 28 ... but ever since - even with 'better' gear and a proper A/B compressor ... never achieved such again.
I think its down to paint viscosity .. I just cannot get it right ...
Old 08-24-2021, 11:44 PM
The Professor
Professional Nerd
Default Made a decision...
So the Chinese airbrush is bin-bound.
I looked at several 'top brand' air brushes, but realised they all seem designed for precision artwork. People seem quite happy that they get lines of less than 0.0X of a millimetre.
Yes I want to be able to create nice narrow lines, but I also want to put a base colour down on fuselage and 40" wings.
I have therefore decided on a Sparmax pistol grip airbrush. It comes with 3 needles from 0.3mm to 0.8mm and a maximum spray width of 60mm.
And halfway between the cost of a cheap dual action and an Iwata. So I hope I am going to be happy. I never thought of using a fridge motor to run it..... I shall have to look into that.
Old 08-29-2021, 01:20 PM
The Professor
Professional Nerd
Default It Lives, It Lives!!!!
So, I used the Sparmax for the first time today, and it is truly Brilliant.
Even on a 0.5mm needle, the coverage is phenomenal. Well worth the money. And very comfortable to use.
GregG7
07-17-2018 09:12 AM
Mysterious
3D Flying
25
08-19-2016 07:45 AM
RightFly
08-30-2011 06:43 PM
TylerJCooper
03-10-2011 04:37 PM
Quick Reply: Airbrush Suggestions Please.
Page generated in 0.07282 seconds with 12 queries
