Rudder Aileron Mixing on DX6i
Old 01-15-2015, 08:40 PM
mikeweber3
Default Rudder Aileron Mixing on DX6i
My old Futaba just had a physical switch to mix aileron and rudder.
I learned to fly a real airplane in a 1946 ERCOUPE if anyone knows what that is . Some of them don't have rudder pedals.
Anyway, I haven't found the setting in my Spektrum radio. Any help?
mikeweber3 is offline
Old 01-15-2015, 08:54 PM
Just pick a user mix and mix them yourself.
Some radios have the rudder-aileron/aileron-rudder mix as a built in function.... some don't. DX6 is a lower end radio with less mixing features.
I almost bought a full scale Ercoupe in 1990... I should have.
Old 01-15-2015, 10:25 PM
Yes Mike, you'll have to go to the MIX screen and create your own AIL> RUD mix. You can also set how much you want it to mix(in each direction), if the RUD trim is affected by changes of AIL trim, and choose if it's always on or if you can turn it on/off with one of the mix switches. Let us know if you need help creating the mix. I've upgraded from my 6i, but I can dig through the manual and maybe it'll trigger some of my dormant brain cells!
Old 01-15-2015, 11:07 PM
mikeweber3
Aaaahhhh. Which leads me to my next question.
Where is the dormant brain cell trigger ����
Old 01-16-2015, 01:13 AM
Lol! Ok, I had a look. It's on pages 36-38 of the manual.
How basic do you need these instructions? I'll assume you know how to get onto the ADJUST LIST screen, then scroll down and select MIX 1.
The 2 channels presented are master (left) and slave (right). Change them to AILE> RUDD. The next line is the rates. The manual shows U and D for those. Up/Down? Maybe they'll change to L and R when you select aileron for the master.
Below on the left is switch selection. The manual lists the choices here.
Then lower right is 'Trim Include'. You choose if trimming the master channel effects the slave.
Pretty easy once you do it once. Let me know if that works for you. Good luck!
Old 01-16-2015, 01:34 AM
mikeweber3
Xmech
I got it ��
Old 01-16-2015, 01:36 AM
mikeweber3
Default Euro coupe
Fhuber
Cool, how much? If I remember correctly my dad sold his in 74 for $4600
Old 01-16-2015, 01:53 AM
It was unbelievably low price including flying lessons....
Old 01-16-2015, 02:42 AM
Glad you got it. Oh yeah, make sure the rudder is moving the right way on the plane with the mix! If your rudder works fine from your rudder stick input, but reversed in the mix, just change the numbers in the U and D from + to _ and vice versa. I guess if you did this with the planes powered on, you'd have seen it already.
Old 01-16-2015, 05:25 AM
gadgeter
It's a Possibility!
gadgeter's Avatar
The Exponential feature is great for lessening the downward throw of ailerons while keeping upward where it needs to be. Thus keeping drag to a min.
gadgeter is offline
Old 01-16-2015, 03:01 PM
mikeweber3
Gadgeter,
I'm still learning my radio. Can you expound on the Exponential feature and where to find it in the menu (DX6i)
Old 01-17-2015, 12:13 AM
gadgeter
It's a Possibility!
gadgeter's Avatar
Xmech may be better at this one.
gadgeter is offline
Old 01-17-2015, 01:12 AM
gadgeter
It's a Possibility!
gadgeter's Avatar
I misspoke about exponential. Its travel adj you have to use in each direction to limit one way like down Ail. vs up
DR/EXPO has to do with rate of signal and sensitivity. Expo changes the sensitivity of the stick relative to "0". In other words it can be less sensitive around the 0 or neutral position than out towards max. where travel can be more on the surface per movement of stick. Higher value on radio = less sensitive.
Confused yet? I'll do it to ya
gadgeter is offline
Old 01-17-2015, 02:56 AM
Looks like Gadgeter already gave as good an explanation for expo as I can give.
Your dual rates and expos are set on one screen, under the Adjust List menu, it's the D/R&EXPO page. But before you mess with that page, the 6i has separate switches for the DR's of the aileron, elevator, and rudder. I prefer to control them with one switch. In the Setup menu, go to the D/R COMBI page, and you can select one switch to control all of them. This is on page 46 in the manual. The D/R&EXPO info is on page 62.
I think if you set your dr and expos first, then put them on one switch, you'll have to go back and re-enter your info in the dr&expo screen again. So you want to choose your switch first.
Old 01-19-2015, 07:44 PM
E-Challenged
E-Challenged's Avatar
I'm still trying to learn how to set up 3-position flaps on a switch with adjustable throws and slowed servo movement with adjustable down elevator offsets using my $%&* Aurora 9 system. I'm surprised nobody admonished the OP for wanting to use coupled aileron/rudder. I use it most of the time with my scale models, but it is habit forming.
E-Challenged is offline
Old 01-19-2015, 07:57 PM
Lol! Yes, where are the purists!? I've tried it, didn't work for me. It was to try to alleviate a bad adverse yaw issue on my old Phase 3 P-40 (rest in pieces), and while it seemed to work on that, I didn't care for it all the time, and I usually carry rudder through the turns to keep the tail up anyway. I found it better to use differential ailerons. But that was for me. I'm not gonna judge!
Old 01-20-2015, 01:58 AM
mikeweber3
Default Yes!!!, It flys
thanks to all who helped me !!!!
After 20 years in the shed she got a new electric engine, 2 5500 MaH 3 cell batteries, some mono kore patches, and she flew great
I flew about 18 minutes and used up 3400 MaH.
I guess you never forget how to ride a bike eh
Old 01-20-2015, 02:10 AM
gadgeter
It's a Possibility!
gadgeter's Avatar
Echallenged, start a new thread and I might can help explain the mixing with limited directional throws
gadgeter is offline
Old 01-20-2015, 02:34 AM
Congrats Mike!
04-29-2014 03:45 AM
bamaerker
02-23-2012 05:21 AM
MbK_The_GLow
01-19-2012 08:54 PM
Swanj
08-26-2011 06:19 PM
Quick Reply: Rudder Aileron Mixing on DX6i
Page generated in 0.12288 seconds with 12 queries
