KW club
Old 02-09-2010, 01:47 AM
  #151
aramsdell
aramsdell's Avatar
Coming soon, my Plank entry for the KW club. 72" Nitroplanes Yak 54 with Exceed monster 160 and 21 X 8 electric wood prop. Didn't get pics of the Wattmeter tonight but unofficial 2550W, 67 amps, no rpm's yet. Hey it was almost dark. Hobbywing 100A HV opto. Pulls almost like a 50CC.
aramsdell is offline
Old 02-10-2010, 01:49 AM
  #152
lmopar69
Gravity Stinks!!
lmopar69's Avatar
I think we should get multiple KW club icons. I have planes in the 1kw, 2kw and 3kw groups... then again, if we did that, maybe my little space would get a little bit too filled up.
Laine.
lmopar69 is offline
Old 02-10-2010, 03:04 AM
  #153
aramsdell
aramsdell's Avatar
These from after work today. 66 amps, 2450 watts. I'm impressed with the Exceed 160. Not as much with the prop, too noisy- I think the tips are flexing.
Changed to high timing. Making 2550 W.
ID:	120219   Click image for larger version
Old 03-22-2010, 08:01 AM
  #154
jasmine2501
Custom User Title
jasmine2501's Avatar
I take it helis don't count? I'll post a ICE ESC log when I get around to it, from a new plane.
jasmine2501 is offline
Old 03-22-2010, 08:54 AM
  #155
Helis Count Jasmine, its e power Right Like Larry Is Going to Say shortly in the next post, Watts Is Watts
Old 03-22-2010, 08:55 AM
  #156
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Why not? I think they should count just like planes. Watts is Watts after all
I am somewhat biased though. Later on Im going to be posting a log file from my Raptor that gets me into the 2kW range
In the mean time, here is a log from BUFY that get me to about 1150 watts.
Larry3215 is offline
Old 03-22-2010, 12:10 PM
  #157
Larry3215
Larry3215's Avatar
Oh no! Chellie is psychic!
Old 03-22-2010, 07:31 PM
  #158
jasmine2501
Custom User Title
Wait... you have an electric Raptor? Links? Info? I fly a Trex 500 - I know it makes over 1000 watts periodically, but I don't have any way to measure it.
Old 03-22-2010, 09:01 PM
  #159
MaxAdventure
AMA 198798
MaxAdventure's Avatar
search this thread, several helis are posted
MaxAdventure is offline
Old 03-22-2010, 10:17 PM
  #160
jasmine2501
Custom User Title
Yeah I did go back and read a bit after I posted the stupid question
My Bad...
Old 03-23-2010, 12:02 AM
  #161
Jasmine and Larry, be sure to post all the details.
Don Sims is online now
Old 03-23-2010, 12:04 AM
  #162
Laine.
Laine, missed this earlier. I don't see why we couldn't post for each if you document each. More salad is good isn't it?
Old 03-23-2010, 12:12 AM
  #163
Default 4Kw
I guess I should go ahead post it up... Did my first runs last night and here is the power reading from the new Big Pitts!
4224 Watts on a 12s setup swinging a 22x10 Pro Zinger, even with a smaller 21" APC I'm still in the 4k range.
http://www.youtube.com/watch?v=aJVh7ViPM74
ID:	123737   Click image for larger version
Old 03-23-2010, 02:42 AM
  #164
scott-p
crash test pilot
scott-p's Avatar
I couldnt get the vid to work
edit...and where did you get the power meter? I saw one online for $44.95
scott-p is offline
Old 03-23-2010, 02:46 AM
  #165
try it again Scott, seems to be working ok now
Old 03-23-2010, 02:50 AM
  #166
scott-p
crash test pilot
scott-p's Avatar
it works now!!! haha looked like your head was in the path of the prop if it were to come loose. kinda scary. Where did ya get the power meter?
scott-p is offline
Old 03-23-2010, 02:55 AM
  #167
Oh no, I was behind it for sure!
That's an Eflite Wattmeter, got it at the LHS but you can pick them up from Horizon. I like the watts up type meter better since it shows everything at once. I got this one before I knew about that one.
http://www3.towerhobbies.com/cgi-bin...&I=LXLMV0&P=TF
Old 03-23-2010, 02:59 AM
  #168
scott-p
crash test pilot
scott-p's Avatar
I wonder if you can get 1kw out of a 60 amp esc? I might have to get a new motor and prop for the pulse and change out the power 32 it has on it now.
edit...22 in prop...WOW
scott-p is offline
Old 03-23-2010, 03:07 AM
  #169
Hard to say without trying. I have a Welgard 4130/08 running on 8s lipo and an HV 80 amp esc on my Shoestring and it is getting right at 1100 watts on a 13x10 APC.
I have had it clocked on radar at 87mph into a pretty stiff wind at SEFF lat year. keep in mind that is a 7.5 pound 1/4 scale plane too!
Old 03-23-2010, 05:32 AM
  #170
Originally Posted by larry3215 View Post
oh no! Chellie is psychic! :d
:d :d :d lol
Old 03-23-2010, 06:02 AM
  #171
Larry3215
Larry3215's Avatar
Here you go Don
Plane: BUFY - Big Ugly Foamy Yak 6.6 pounds all up weight
Motor - Medusa 3660-1100 inrunner
MEC Monster box gear box at about 6.2/1
Castle ICE 60
9S1P A123 pack
APCE 22x10 prop
1150 watts peak.
24.6 Volts at 46.7 Amps
Old 03-23-2010, 06:05 AM
  #172
Larry3215
Larry3215's Avatar
Depends on how many volts the esc can handle.
1000W/60 amps = 16.66 volts.
So if you are using at least 5S lipo packs, then you could easily hit 1000 watts. With 6S or more you could get well over 1000 watts on a 60 amp esc
Old 03-23-2010, 06:06 AM
  #173
groundrushesup
groundrushesup's Avatar
Yeah, it is possible. In fact stay tuned. I plan to have my Shoestring on the bench this weekend with a 11x8.5 on 6S - prediction is 51A so 51A * 20v (under load, being conservative and considering losses) = ~1Kw. Pitch speed is predicted in the 90's with 7lbs of thrust. Should be a hum-dingah.
That being said, I plan to run this bird on an 80A but the Plush I got from HC was DOA, so I will test it on the 60. My feeling is that 51A on a 60A is cutting it too close when an extra $15-20 can give you a 30A cushion. I am using a Dimension Engineering SportBEC for the servos and Rx but still I don't like to push my ESCs over 75% if I can help it. I also plan to try out that APC 11x10 I've had in my box looking all lonely, just acheing to go fast
GRU
groundrushesup is offline
Old 03-23-2010, 06:34 AM
  #174
Larry3215
Larry3215's Avatar
I picked up a Raptor E550 last fall. After my last unscheduled 'up-grade opportunity' I stretched it to the Raptor 50 Titan/E620 boom and Im running 600mm blades now.
I dont have a build thread on it. Its really not much different than any other E Raptor other than Im using an inrunner and the A123 pack option.
Average power usage during a typical flight is around 700 watts. Full collective punch outs hit just over 2kW. On the flight below I hit 2101 watts. It should go up a little more once I dial in the full collective available. I have it tamed down a bit for now while Im still getting used to the machine
The Raptor is my favorite heli so far. It is very stable and smooooth in the air. I have had a Logo 10, Logo 20, Maxir, Dragonus and now the Raptor. The Logo 20 came the closest but the Raptor is the best all around heli of the bunch.
Heli = Raptor E550 with 600mm blades and R50Titan boom
motor = Medusa 3670-750 inrunner
Castle HV ICE 60 controller
10S1P Polyquest 5000 lipos or 12S1P A123 packs
Peak power 2101 watts
Name:	2kw raptor.jpg
ID:	123758   Click image for larger version
ID:	123759   Click image for larger version
Name:	IMG_6072 (Medium).JPG
Old 03-23-2010, 11:14 AM
  #175
GRU
Is that the new smaller Shoestring? Mine is the old glow model that I converted to electric.
[media]http://www.youtube.com/watch?v=FtuukImCdL0[/media]
Quick Reply: KW club
Page generated in 0.15564 seconds with 19 queries
