KW club
Old 05-04-2016, 08:30 PM
  #326
Xpress..
Team Hitec, CSR
Xpress..'s Avatar
Plane
Extreme Flight 88" Yak 54
Motor
Hacker A60-18L
ESC
Jeti Master Spin 99 OPTO
Battery
6s 5000 30C Turnigy in 12s2p configuration
Prop
Xoar 24x12PJN
3,486 watts. Sure yanked that airplane around real awesome, I miss it.
https://www.youtube.com/watch?v=moVR6f7kq0Q
Xpress.. is offline
Old 05-04-2016, 08:43 PM
  #327
Originally Posted by Xpress.. View Post
Plane
Motor
Hacker A60-18L
ESC
Battery
Prop
Xoar 24x12PJN
3,486 watts. Sure yanked that airplane around real awesome, ]
What RPM do you get on that 24X12 prop?
Old 05-04-2016, 08:45 PM
  #328
Xpress..
Team Hitec, CSR
Xpress..'s Avatar
It's been a couple years since I had that airplane, before it piled in. I believe I was turning around 6550 on the ground.
Xpress.. is offline
Old 05-04-2016, 09:33 PM
  #329
Wish I had data on the Brio I ran on 12S...
Maybe I have a log saved from the Turnigy Super Brain 100 somewhere.
6550 sounds a little low for that system.
Old 05-04-2016, 09:46 PM
  #330
Yeah
6500 RPM on 24X12 prop is around 5700 Watts.
Old 05-04-2016, 09:59 PM
  #331
Xpress..
Team Hitec, CSR
Xpress..'s Avatar
Static RPM using a TNC Tachometer was ~6900rpm on an APC 24x12. This was still in my testing phases and using a Castle Edge 120 HV which reported closer to 5000 watts and almost 100 amps with its built in data logger.
I switched to the Jeti ESC since the Castle was giving me issues, but never took down RPM data, only wattage.
Xpress.. is offline
Old 05-04-2016, 10:09 PM
  #332
Get above a certain rpm static and the prop unloads because the blades stall. Watts can drop significantly.
Even Motocalc will recognize this.
Update the Castle firmware and it might cure its issue. They had an update relatively recently that makes a huge difference.
Old 05-04-2016, 10:20 PM
  #333
Xpress..
Team Hitec, CSR
Xpress..'s Avatar
As I wrote in one of my previous responses, I have not had the airplane nor the setup installed in an airplane for years and that I originally had a Castle ESC (with the latest firmware at the time) but switched to a Jeti ESC because I could never get the Castle ESC to work properly.
The prop was not ripping on the ground. It could be 5900 rpm but again, it's been years since.
Xpress.. is offline
03-26-2014 08:27 AM
theluckyone17
04-28-2008 07:06 PM
neilg.
General RC E-Heli Talk
12
04-12-2008 05:06 AM
cwarburton
Batteries & Chargers
11-15-2006 11:48 PM
skromfols
07-09-2006 06:49 AM
Quick Reply: KW club
Page generated in 0.08764 seconds with 17 queries
