3D Printing Post your electric plane related 3D ideas and plans.
3D print section for ideas / files / requests ?
Old 09-08-2017, 07:26 PM
Default 3D print section for ideas / files / requests ?
A dedicated section to 3D printing ... ?
Where we could submit 3D files / ask for ... communicate about ?
Old 09-08-2017, 07:56 PM
formontoya
Well then, the first thing that needs to show up is some planes to start 3D printing...
https://3dlabprint.com/
formontoya is offline
Old 09-09-2017, 02:32 AM
Lets try it out, the forum should be good to go.
Old 09-18-2017, 08:13 AM
RepRapper
Default Wheels
Lets get things started with some simple 3D printed wheels intended for lightweight electric airplanes. I live an hours drive from the nearest hobby shop. So I design a lot of the parts I need and put them on thingiverse. Everything on Thingiverse is free for you to use.
This is a 70mm shock absorbing wheel similar to the GWS Slowstick wheels. For some reason they dont display right but they do print right.
If you like them and want to print this wheel the files can be downloaded at:
https://www.thingiverse.com/thing:2519037
RepRapper is offline
Old 10-06-2017, 12:37 PM
One aspect that could really help - is where some of us are not so good at designing / creating. If those who are adept at it - could help create objects ?
I have a particular interest for this one ... creation of the canopy / cowls / bombaimers / gun turrets etc. for my Lancaster. I followed all sorts of tutorials / youtube vids - but still no joy !!!
Its also interesting if someone identifies an object that can replace broken part of a different model ....
I found a cowl that is close copy of the WOT4 cowl ... trouble is I didn't note which files !! When I find it - I will list.
Just for the record ... Thingiverse does actually also list items that are not free - luckily not so many !! Those I just skip past !
Old 10-06-2017, 12:39 PM
I just paid $20 for the P51D files .....
First part is on bed printing now ... front fuselage ... 6 hours worth just for that !!
Just hope nozzle keeps going and not block.
Old 10-06-2017, 08:36 PM
RepRapper
I used to have a lot of trouble with clogging nozzles. It turned out to be one of two reasons. The first was too low of temperature. I now print my PLA parts at 237 C. This helped a lot. No more clogged nozzles. And a lot better layer adhesion. Very important for 3Dlab prints. Second was related to when the fan turns on for the print. If the fan turns on to late the filament gets to soft and does not push through the nozzle correctly. It builds up and clogs. You have to warm up the hot end to pull it out. Cut off the thick end and restart.
Old 10-06-2017, 10:20 PM
formontoya
Very cool...would like to hear how things go for you. I plan on getting a 3D printer for Christmas as I've been drooling for 3 planes they have. Buddy prints quad frames that work nicely...just purchases aluminum spacers to put upper/lower sections together.
Old 10-07-2017, 08:57 AM
Ran into a problem .... rear fuselage section is too high for my printer. Will be seeing if I can 'cut' of a section to separately print.
Will be contacting 3Dlabprint about it as well.
Old 10-07-2017, 10:43 AM
Meshmixer to the rescue !
Sliced in half the offending pieces ....
Flite-Metal
278
07-21-2021 04:14 AM
RepRapper
12-29-2014 03:57 AM
Quick Reply: 3D print section for ideas / files / requests ?
Page generated in 0.08273 seconds with 15 queries
