Strange Outrunner Shaft.
Old 04-26-2010, 01:43 PM
Big Johnny
Master Of The Crash
Big Johnny's Avatar
Default Strange Outrunner Shaft.
Hey guy's check out the pictures and tell me if you have seen this before.
I have 2 KDA 36-10XL brushless motors. The shafts on mine step down, what would this be for? Photo # 1 Hobbycity Stock photo, #2 My motor.
ID:	126358   Click image for larger version
ID:	126359   Click image for larger version
Big Johnny is offline
Old 04-26-2010, 02:40 PM
mesh
Hobbycity claims the motor has a 5 mm shaft, it looks like yours has just been turned down to maybe 3 mm. I guess the factory changed it without telling hobbyking Maybe the 3mm shaft is more appropriate for the type of collets or spinners mostly used on that size motor. I doubt the step down has a purpose other than that.
mesh is offline
Old 04-26-2010, 03:30 PM
groundrushesup
groundrushesup's Avatar
Often the shafts are milled to accept pinions with a certain ID - usually for helis.
groundrushesup is offline
Old 04-27-2010, 12:31 AM
1320fastback
1320fastback's Avatar
I see the problem, if you turn your motor around like in the HK picture it will be o.k. and the step will not be there anymore
Did it come with a collet? Does it fit?
1320fastback is offline
Old 04-27-2010, 05:01 AM
the shaft is fine like that, the benefit is that the motor has larger 5mm bearings in it, and that makes it stronger IMHO take care, Chellie
Old 04-27-2010, 05:38 PM
cliffh
That is a great point Chellie. One that I missed completely. I couldn't come up with a good reason for the shaft being like that.
Cliff
cliffh is offline
Old 04-27-2010, 10:03 PM
cyclops2
The reason for that little " useless " step there. It prevents anyone from pushing the prop saver OR prop adapter tightly against the snapring and causing friction if the snapring reaches the outer stationary part of the bearing. It is a standard feature on all well designed motor shafts.
Heli motors have the shaft comming out of the large rotating magnet housing. The shaft is set screwed to it. The step is not needed on them.
Still, the same shaft design CAN be used on both types to reduce special parts inventories.
cyclops2 is offline
Old 04-27-2010, 10:30 PM
cyclops2
Default Caution
I know of the following mm shaft sizes.
2.3
3.0
3.17
3.2
I would be VERY SURE of the fan rotor hole size before selecting ANY motor.
Also . Sometimes the motor shafts are a little Fat. Run it at VERY LOW speed and gentle pinch a super fine sandpaper on it for 2 second at a time. Keep checking the fit, so you do not over do it.
cyclops2 is offline
Old 04-28-2010, 11:47 PM
cyclops2
Default My first straight shaft with no step down.
The BP A2217-9 970 KV has no step. 4 mm all the way. Sturdy looking motor.
Maybe it will be good for using in unplowed fields ?
cyclops2 is offline
Colt187355
11
08-20-2009 06:35 PM
WRX Dave
01-15-2007 03:22 PM
gravityrules
07-25-2006 11:49 AM
fabricator
09-23-2005 07:34 PM
Quick Reply: Strange Outrunner Shaft.
Page generated in 0.10975 seconds with 13 queries
