Extending prop shaft on E-flite 300 outrunner
Old 12-27-2006, 11:29 PM
WRX Dave
Default Extending prop shaft on E-flite 300 outrunner
I have the E-flite 300 outrunner and I can't seem to extend the prop shaft to install a spinner. I removed the two front screws as well as the c-clip and lock ring from the back of the motor as per the instructions but the shaft won't budge. I gently tapped it and it didn't move. Anyone know what I can do here?
WRX Dave is offline
Old 12-28-2006, 07:25 AM
thunder 21
there are 2 set screws did unscrew both
thunder 21 is offline
Old 12-28-2006, 03:22 PM
WRX Dave
Unscrewed them both. Also I can start to pull the outer casing foreward so it's not catching on the rear bearing. Would it be safe to try to heat the hub to expand it? I think that's where it is stuck.
WRX Dave is offline
Old 12-29-2006, 07:41 AM
thunder 21
can u push the shaft back the other way thenremove the case and inspect 4 burs wich could be holding it back..
Old 01-05-2007, 10:56 PM
WRX Dave
Won't budge in any direction.
WRX Dave is offline
Old 01-06-2007, 02:22 AM
cyclops2
If new, you have a factory reject.
Leave it alone. Use it on some other plane.
Press too hard and buckle a shaft or ruin some threads. You choice.
I know everything. And it sounds like I would leave it as is.
cyclops2 is offline
Old 01-11-2007, 01:43 AM
WRX Dave
Well, thanks for the help anyways. I threw an rubber band on top of the regular prop saver and it seems to be keeping it in place better during aerobatics.
Stupid gyroscope effect.
WRX Dave is offline
Old 01-15-2007, 03:22 PM
Matt Kirsch
Matt Kirsch's Avatar
Dave,
Do you know anyone with a small arbor press? You need firm, even pressure to break that shaft loose from the bell.
Matt Kirsch is offline
DJT
Brushless Motor Construction
03-05-2008 05:59 PM
Fangar
07-31-2007 07:51 PM
hookedonflyin
02-01-2007 08:55 PM
gravityrules
07-25-2006 11:49 AM
debhicks
New Product Announcements
01-25-2006 01:36 PM
Quick Reply: Extending prop shaft on E-flite 300 outrunner
Page generated in 0.08735 seconds with 10 queries
