Spinner nut falls off - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-23-2012, 04:34 PM
waterfire
Default Spinner nut falls off
I'm new to airplanes and I need some help. I have a used O.S. Surpass 4 stroke .48 engine.
I have no problem starting and running it, it's just that the prop spinner keeps getting loose.
One question: the engine turns ccw standing in front, the prop nut is a right hand thread, the starter
rotates ccw....so... if I keep using the starter ccw and the spinner is a right thread won't it keep
making the prop spinner loose all the time....Do they make a cw spinner? thanks
waterfire is offline
Old 07-23-2012, 04:36 PM
Double nuts help a great deal on 4 stroke engines. You might be a bit to wet causing the detonation too early too.
We are dedicated to "e" flight here but thought I would help out with that.
Old 07-23-2012, 05:24 PM
Really should be posted in a Glow Engine forum ........... but anyway ..
4 strokes are notorious for shaking nuts loose and of course here you have a starter cone that is also trying to undo the nut against higher compression 4Stroker.
Solution ? If the double nut is not suitable - then you fit a proper spinner that covers the prop nut. Then starter will then be applied to a spinner instead of to the prop nut. It is not a good idea to use a combination prop-nut - spinner on such an engine.
Now here's a strange thing ... how big is the hole in the rubber starter cone you use ? The cone is reversable ... big hole for spinners, little hole for prop nuts. BUT I never used the small hole - preferred to bear the starter cone onto the prop ...
Old 07-23-2012, 05:48 PM
Rodneh
The screw pitch as it should be, if it were reversed you would have many more problems as each firing of the piston would tend to loosen the nut. What is kicking your prop off is that it is backfiring, probably to rich a mixture setting.
Rodneh is offline
Old 07-24-2012, 12:28 PM
RED Locktite that Nut On, Problem Solved Heat Nut with Cig Lighter to get Back off
Please push that Thank Button so i wont have 1,666 Thanks but rather 1,667 , Thank You, Chellie
Old 07-24-2012, 02:37 PM
NO! Never do this! Red is for permanent connections and certainly not appropriate for a propeller!
Double nut and your too much prime (too wet). I have never had double nuts fail to hold on my 4 strokes ever.
Old 07-24-2012, 03:22 PM
Rodneh
Stay away from any type of locktite on that prop shaft.
Rodneh is offline
Old 07-24-2012, 04:42 PM
Sorry Chellie ... not often I disagree with you ... but here is one time - NEVER use loctite on any prop nut ! Double nuts, locknut .... there are many ways to cure it but not Loctite please.
Old 07-24-2012, 08:05 PM
The Red Locktite is for Extrem cases, when nothing else will work, it will come off, but you have to heat it
Old 07-25-2012, 12:02 AM
hayofstacks
hayofstacks's Avatar
I use red locktight on my electric motor nuts and motor mount mounting screws, and have never had a problem getting them off.
hayofstacks is offline
Old 07-25-2012, 12:26 AM
Just remember the red bottle is not red loctite! Red is semi-permanent but can be removed generally only with heat. What color was the actual liquid? Blue is best for that use IMHO
The point is you should not use thread locking compound for propeller nuts and shafts.
Old 07-25-2012, 03:05 AM
Rockin Robbins
Rockin Robbins's Avatar
Would the old nail polish trick work for an IC motor?
Rockin Robbins is offline
Old 07-25-2012, 04:36 AM
hayofstacks
I have used nail polish and super glue as lock tight. Certain super glue's will not adhear to metal and none will if there is any grease.
I just had a bottle laying around from when I did the driveshaft on my old car. I tend to way over tighten fasteners.
Old 07-25-2012, 08:12 AM
I normally use the Blue locktite on prop nuts and mounting screws, but, sometimes you need to use the red Locktite on problem nuts I have only had to use the red Locktite once with a problem prop nut, It never gave me any more problems, I used heat to get it off, i have striped threads trying to remove an Aluminum nut that has been locktite on, so to be on the safe side i heat the nut and then remove it to prevent damage to the threads, I like the Nail polish trick, I have lots of nail polish, and it may be cheaper than Locktite Take care and have fun, Chellie
Old 07-26-2012, 12:25 AM
Rockin Robbins
Nothin' going on around here that couldn't be fixed with an arc welder!
Old 07-26-2012, 01:51 AM
One of my club members uses an aluminum spinner on his 50 cc gasser. That aluminum spinner is keyed into the spinners aluminum back plate. It won't come loose.
mofosheee
07-19-2012 08:22 AM
HiVoltageAir
08-02-2011 02:05 AM
HiVoltageAir
08-02-2011 02:04 AM
FlyWheel
07-16-2011 08:48 PM
gramps2361
03-02-2011 01:53 AM
Quick Reply: Spinner nut falls off
Page generated in 0.12538 seconds with 13 queries
