looking to build a VTOL
Old 06-08-2016, 07:00 PM
mrhouseman1
Default looking to build a VTOL
i understand i can use a drone control board,,,,is that true?....also if thats true is it hard to set up.....also what would be a good control pannel to use.thanks
mrhouseman1 is offline
Old 06-08-2016, 07:46 PM
It really depends on exactly what type VTOL you are attempting.
For something like a scale model of the "Pogo" its likely that any 3axis heading hold capable gyro can do the job.
https://www.youtube.com/watch?v=Nh9dhBJY010
For a scale Osprey or Harrier it would be more difficult and need a more complex gyro system for best result. (even though an Osprey has been done with no gyro, but it couldn't transition back to hover for landing reliably.)
Old 06-08-2016, 07:52 PM
mrhouseman1
Default vtol
so what you are saying or havent said the control board will work or will not work....it would be like the ospray that iam looking to do
Old 02-27-2018, 09:45 AM
goingbush
To resurrect an old thread , about 20 years ago I made a XFV-1 and I believe probably made the first ever fixed wing Vertical take off , in Australia at least.
Now Ive just got back in the hobby after a 15 year break and its all Electric for me now.
I believe I can make this work with a 3-axis stability module , (never existed back in the day)
So thats my next project . I believe I will be able to make a controlled take off with Electric & 15x4 3D prop and a controlled landing too. Hoping ailerons will take care of torque and not bother with the complication of a contra rotating prop.
you can see my previous efforts were impressive but not very well controlled ,
https://youtu.be/nRQ6LW7VSD4
goingbush is offline
Old 02-27-2018, 11:52 AM
Interesting project but a lot of 3D planes will do that now. I don't think it will be quite the challenge you expect.
Old 02-27-2018, 02:35 PM
goingbush
You should remeber that a drone board controls the lift motors (ie the thrust) directly for an almost instant response in both roll, pitch and yaw.
All hover capable planes use this sort of system.
The issue is will a successful 'hover' stability system handle the transition to horizontal flight. Drones get over this problem by not actually "flying".
If your VTOL relies solely on the effect of aerodynamic forces on control surfaces should handle the transition well enough but to be able to hover things get much harder.
With enough power and light weight even an EDF can ROG vertically.
https://www.youtube.com/watch?v=OMXVyAwNMTc&t=47s
Only aerodynamic control surfaces. It does have a plane 'stabiliser' rx although it does flies well enough with it turned off.
Any thoughts on what you intend to build?
quorneng is offline
Old 02-27-2018, 09:29 PM
goingbush
nothing like bursting someones bubble , and your right Ive touched the tail to the ground on prop hangers before, no 3axis gyros back then though , I guess I just want to finalise the project I started 20 years ago
Old 02-27-2018, 09:34 PM
goingbush
Originally Posted by quorneng View Post
goingbush
Now that winged V1 is cool.
I want to revisit the XFV-1 to get me in the right direction, Then I'll have another attempt at vectored thrust , Something else I failed on back when.
https://youtu.be/n-LRNw4wPKI
obviuosly will be all electric.
Old 02-27-2018, 10:17 PM
Some months ago I was offered a Vectored thrust kit to do a review (for Banggood from memory) Not enough reward in it for me so I declined.
Old 03-09-2018, 03:05 AM
glideher
which thrust kit was this?
i find these units are usually very heavy and weigh the plane down making it way to tail heavy and requiring a heavy battery to the nose
glideher is offline
Old 03-10-2018, 01:51 AM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Harrier and F-35
More videos on their devopment channel
www.youtube.com/user/melanie1289/videos
3D printing
ron_van_sommeren is offline
Old 03-10-2018, 05:38 PM
glideher
thats amazing, ive never seen this and thought it can be done, yet alone home made,,,,thanks for the vids
glideher is offline
Page generated in 0.07521 seconds with 13 queries
