Hobby Lobby Mini Leader?
Old 06-18-2008, 11:50 PM
kyle1745
Default Hobby Lobby Mini Leader?
Ok I picked up a Hobby Lobby mini Leader and am trying to find a good power source for it. I have 2200ma batteries but it seems specing a motor for these sometimes takes a degree in electronics...
On the box it claims a 100-150 W so id guess 200 would be better.
Ideas? What motor did you use?
Thanks,
kyle1745 is offline
Old 06-19-2008, 04:42 AM
muidaq
bumpety bump
muidaq is offline
Old 06-19-2008, 04:44 AM
lextek
I picked up the Mini Leader during the crash sale. I ended up using a Just-Go-Fly 450XT. The kit was nice. The landing gear mounting was a weak point for me. I ended up tearing the bulkhead out of the fuse on a tall grass landing.
I'm not sure if you can fit that 2200 battery in the fuse. I used a 1300 and had I tight fit. It actually end up partially above the wing to get the CG right.
lextek is offline
Old 06-19-2008, 12:22 PM
kyle1745
Thanks,
Anyone else?
From what I can tell I should be able to get the 2200 in there but it may have to sit back a little bit which could be interesting.
kyle1745 is offline
Old 06-24-2008, 05:26 PM
muidaq
double-bump.
muidaq is offline
Old 06-24-2008, 05:48 PM
Buck Rogers
A couple of questions - What do you want this plane to do performance wise and what batterys are you using - 3s Lipo?
Buck Rogers is offline
Old 06-26-2008, 04:03 AM
lextek
Just wondering if you've flown your Mini-Leader? Mine lived up to be bought during a "crash sale." I guess I'll stick with foamies for a while..........
Been flying the heck out of my MS Composit Unique!
lextek is offline
Old 07-10-2008, 12:09 AM
Fishjunky
Fishjunky's Avatar
I have a mini leader waiting to be built and am trying to figure out a good power plant option as well. I am just looking for a good pattern type setup.
I'm also a bit gun shy on the balsa plane as all the wood planes I've had so far haven't survived the maiden...
Fishjunky is offline
Old 07-14-2008, 02:53 AM
kyle1745
Just wanted to let everyone know that I finally finished up this plane and went with the following motor:
http://www.e-fliterc.com/Products/De...rodID=EFLM1505
Its a little overkill but the plane flies very well with it.
Another thing I did was move the battery up under the canopy for better balance. It allows me to use a 2200Ma with no issues. The plane flies very well.
kyle1745 is offline
UglyNet
04-30-2008 09:35 PM
jstevens
03-17-2008 08:00 AM
mariog7
03-15-2008 03:51 AM
sb13
01-05-2007 05:45 AM
donjiskra
11-04-2006 01:36 AM
Quick Reply: Hobby Lobby Mini Leader?
Page generated in 0.09422 seconds with 13 queries
