that little motor cap?
Old 04-11-2006, 02:57 AM
spinner
infrequent flyer
Default that little motor cap?
Hello motor-heads!
I'm the new owner of a multiplex space scooter(see space scooter vs. graupner terry thread) and the speed 400 can motor which came with the plane does not have a small capacitor which many motors of this type have. (between the wire connection tabs and the motor case)
Question is - should the motor have one, and if so why and what cap-pacity?
signed: Stymied in Syracuse
spinner is offline
Old 04-11-2006, 10:23 AM
slipstick
There should already be 2 capacitors fitted, one from each terminal to the case to reduce radio interference. They are often fitted internally.
If you're sure they're not already there then it's worth fitting a couple and possibly also a 3rd across the 2 terminals. All should be somewhere around 0.047uF (microfarad) or 0.1uF ceramic disc capacitors. The value is not critical.
slipstick is offline
tim 567
Electronic Builders Workshop
06-19-2008 11:58 PM
Twizter68
Off Topic Chit Chat
03-09-2007 03:33 PM
electricpaps
10-15-2006 10:34 PM
ForestCam
08-29-2006 03:18 AM
Nitro Blast
Scale E-Powered Aircraft
02-03-2006 09:01 AM
Quick Reply: that little motor cap?
Page generated in 0.08917 seconds with 13 queries
