How do I read my watt meter
Old 03-27-2011, 03:03 AM
TylerJCooper
TylerJCooper's Avatar
Default How do I read my watt meter
I recently got this watt meter. I connected it to my RIP FunJet and it reads the W (bottom right hand corner) at 495+. What does that mean?
TylerJCooper is offline
Old 03-27-2011, 03:08 AM
thats your Watts
top left corner is your AMPS
top right corner is your VOLTS
bottom right coner is your Watts
bottom left corner is your Amp Hours
Old 03-27-2011, 03:09 AM
CrimzonRider
Fastest PropHead Crasher
CrimzonRider's Avatar
Have you read the instructions? w=watts, v=volts, a=amperage
CrimzonRider is offline
Old 03-27-2011, 03:10 AM
TylerJCooper
Duh, that makes sense. I found how to read that amps too. Last question is about the volts. If it is dropping to 8.5 on a 11.1 battery, is that bad?
Old 03-27-2011, 03:14 AM
[media]http://www.youtube.com/watch?v=kfs4Bs3H7gw[/media]
TylerJCooper
You will find that I am notorious for asking simple (or stupid) questions. Most the time I am so confused I don't even trust myself reading. That's why I love Wattflyer!!!!
Old 03-27-2011, 03:16 AM
thats 2.83 volts per cell, thats dropping a lot, your LVC will cut off at that voltage, if using a 2.4 radio, use a ubec
Old 03-27-2011, 03:21 AM
TylerJCooper
That is probably why my motor skips at full throttle sometimes?
Old 03-27-2011, 03:23 AM
yes, it very well could be prop down a little
Old 03-27-2011, 03:24 AM
there are no Stupid Questions, its just plain dumb not to ask questions
what motor, prop, lipo, esc are you using to be drawing 500Watts and how many Amps are you drawing
Old 03-27-2011, 03:32 AM
TylerJCooper
Motor - 3700 kv
ESC - 60 A
Battery -11.1 v 30C (Not sure what the C really does and been trying to find info on the effects that has with putting a system together. I understand it has to do with how much can get pulled off the battery at a time, but not sure what are the practical differences of running a 20C vs a 30C. I know it would drop my volts more with the lower C, but not sure how to know what C rating I should be using)
Prop - APC 4.75x4.75
Meter says I am drawing about 50 amps
Old 03-27-2011, 03:33 AM
TylerJCooper
PS - That video was SUPER helpful. Thanks!!!!!
Old 03-27-2011, 03:44 AM
TylerJCooper
You have steered me away from HobbyKing ESC, should I also stay away from their ubed?
CrimzonRider
Your not askin stupid or simple questions, just you gotta read lol
Sometimes I have to read something 3 or 4 times before it makes sense.
I am here at wattflyer to learn too. Sometimes it is kinda 'CANT SEE THE TREE THROUGH THE FOREST'. All good My simple questions usually have a simple answer that I am trying to hard to complicate!!
have a good one
cr
Old 03-27-2011, 03:45 AM
Motor - 3700 kv
ESC - 60 A
not enough battery at 1800mah 30C, use a 2250mah 3 cell 40C, use WOT in short burst, the C is the Capacity of the lipo, a 2250mah 40 C is a 90 amp lipo, a 1800mah 30 C rated is a 54 amp lipo, 1.8 amps x 30C =54 amp lipo, 2.25 amps x 40C = 90 amp lipo.
Old 03-27-2011, 03:49 AM
heads up rc has a very good UBEC
http://www.headsuprc.com/servlet/the...iversal/Detail
here is a nice 40C lipo for you
http://www.hobbyking.com/hobbyking/s...idProduct=9942
TylerJCooper
That is beautiful. I have read that equation a few times but it never made sense. Now that I have a watt meter and a plane that it applies, it all make sense. Your the best!
Old 03-27-2011, 03:51 AM
TylerJCooper
"By George I think I got it"
Sure explains why my batteries were getting hot. You should have felt the 1300mah 20C.
Old 03-27-2011, 03:54 AM
[QUOTE=TylerJCooper;796236]That is beautiful. I have read that equation a few times but it never made sense. Now that I have a watt meter and a plane that it applies, it all make sense. Your the best![/QUOTE]
Of Course Thats what They all Say LOL
Old 03-27-2011, 03:56 AM
TylerJCooper
Those are the ticket, however, I use a different connector on my battery and my soldering is getting worst. (Might be the 5 yr old $15 Radio Shack solder gun) Can I order them with different connections?
Old 03-27-2011, 03:58 AM
just solder up a short adapter, that what i did radio shack has a nice soldering gun, get at least a 100 watt soldering gun
Old 03-27-2011, 04:00 AM
tighten the locking nuts on your gun tip, they get loose and will not get the tip hot enough
Old 03-27-2011, 04:07 AM
TylerJCooper
So my 30 watt is not helping? Explains why I have to hold it together for 45-60 seconds. It took me 2 hrs to get the watt meter set-up
How about this one?
http://www.harborfreight.com/180-wat...-gun-4328.html
What type of core do you use?
Old 03-27-2011, 04:12 AM
Brner
AMA16634
How about this one?
Your link is no good...I think you're looking at this one...
http://www.harborfreight.com/catalog...=soldering+gun
Brner is offline
Old 03-27-2011, 04:19 AM
TylerJCooper
Yep that is the link. Thanks! Any thoughts?
Quick Reply: How do I read my watt meter
Page generated in 0.12082 seconds with 10 queries
